can i get a bbk?
Old Jun 22, 2008 | 06:56 PM
Relentless4577's Avatar
Relentless4577
Default can i get a bbk?
will a big brake kit fit on a wheel set up that is 18x8+25 all around?
(just looking for front brakes)
Old Jun 22, 2008 | 07:35 PM
Spork's Avatar
Spork
Depends on the wheel
Old Jun 22, 2008 | 07:41 PM
Relentless4577
Default hmmm well
here's my set up.
front tires are 225/45/18
rear tires are 245/45/18
the rims are 18x8+25 all around.
what's the biggest brake kit that i could put on this set up?
thank you.
Old Jun 22, 2008 | 08:32 PM
terrasmak's Avatar
Originally Posted by Relentless4577
here's my set up.
thank you.
Still depends on the actual wheel, some will fit fine, others will hit with a BBK.
Old Jun 22, 2008 | 08:38 PM
Relentless4577
ok so how would i find out this info? to be honest i don't even know what brand bbk i would get, but it's just something i would like to add to my car as a mod, if you will.....i guess it's more of an upgrade.
Old Jun 22, 2008 | 08:42 PM
DaytonaRoadster's Avatar
DaytonaRoadster
wilwood BBK should fit that..i think
call some manufactures and find out
Old Jun 22, 2008 | 08:55 PM
Relentless4577
right on thanks again!
Old Jun 22, 2008 | 09:51 PM
Spork's Avatar
Spork
Are you referring to stock wheels??
Old Jun 23, 2008 | 01:49 AM
Rippe's Avatar
Rippe
stoptech have a paper cutout you print out that you use to check if the calipers fit the wheel, very easy to use
Old Jun 23, 2008 | 05:20 AM
OnADimePBS's Avatar
OnADimePBS
You'll fit a 13" BBK and a more then likely a 14" kit as well. The only hangup you'd have is the offset.
Todd does a great job outlining what one should do to see if a kit would fit XX wheel. Measure out from the center of the wheel to the radius of the specific rotor (13" rotor > measure out to 6.5") and take measurements along the way.
Then call up different manufacturers and get their specifications.
Todd's Website
Our Specifications
Compare Todd's "X" with our "A" measurement.
Hope this helps for any other kit you may be interested in as well.
Alex
seagrasser
Oct 11, 2015 03:27 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
