Brake Noise Help
Old Jul 25, 2008 | 12:08 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by gmueip
I've had my OEM replacement Axiss rotors and brake pads installed for about three months. They screathed a bit when I first got them but then it went away. Lately, everytime I stop from low speeds I hear them squeal and when the car is rolling at low speeds I can hear a screathing sound (kind of like metal on metal). The sound is not too loud but it's enough to annoy the hell out of me. Should I buy some anti squeal spray for the breaks or should I take the car in to a shop to have it checked out? I just don't know if the spray will do the job for what I described.
Must I post some noods of chicks for advice?
See my write-up, starting with post #4. It should answer your questions.
https://my350z.com/forum/brakes-susp...rs-brakes.html
And yes, I will take the n00ds....
Old Jul 25, 2008 | 01:40 PM
03redlinetrack's Avatar
03redlinetrack
I believe I solved my squealing noise. I changed my pads out and after 2 weeks so far, nothing. I'm sure that isn't the solution for everyone else with this squealing noise... I was pry just lucky.
Old Jul 25, 2008 | 08:33 PM
jmwammock's Avatar
jmwammock
hey fellas, I have the same noise and problem with my front brakes, the noise drives me nuts, I took it to my long time mechanic this morning and we took it for a drive, he looked at it and said some idiot who owned the car before me put some cheap azz metal pads on it and put one of the shims and wear clip was put on wrong and its rubbing against the rotor, I've got an appointment for him to put on some high performance ceramic pads and ruff up my rotors and put it on the right way. Hope this helps some of you, i'll post tuesday after he does it to verify.
Old Jul 28, 2008 | 10:07 AM
gmueip's Avatar
gmueip
Hi Kids!
Thank you sir!
Old Jul 28, 2008 | 01:08 PM
VO...'s Avatar
VO...
Administrator
Thank you sir!
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
