Brake Bias Valve???
Old Aug 11, 2008 | 12:37 PM
Colin_S's Avatar
Colin_S
Default Brake Bias Valve???
On fitting my rear sway bars i noticed a small 'thing' which bolted on to one side of the sway bar/end link. Is this a brake bias valve and should i be concerned about how it attached back on as you could not bolt it back on exactly the same.
Old Aug 11, 2008 | 07:40 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
pic?
Old Aug 11, 2008 | 09:46 PM
terrasmak's Avatar
Originally Posted by Z1 Performance
pic?
+1 , never seen it and changed many sway bars.
Old Aug 15, 2008 | 11:23 AM
Colin_S's Avatar
Colin_S
Old Aug 15, 2008 | 11:45 AM
terrasmak's Avatar
OK i'm now really lost , i have never seen one of them.
Old Aug 15, 2008 | 11:54 AM
shakuya88's Avatar
shakuya88
You wouldn't happen to have RAS would ya? Either that or maybe something to do with the alignment. I thought stock brake bias was in the master cylinder or something else up in the engine when the lines all split to each wheel.
Old Aug 15, 2008 | 11:57 AM
Tac-M's Avatar
Tac-M
i have NEVER seen this ! ever ! what is it ??? !!!
Old Aug 15, 2008 | 12:05 PM
JasonZ-YA's Avatar
JasonZ-YA
Default non US spec?
Well, im guessing maybe it is some kind of non-US spec part, because i dont see it in the parts breakdown below - via courtesy parts.com
It is OEM because i see where it attaches and says "NISSAN" so maybe the OP can read the part numbers and we can do a internet search under those numbers??
im having a hard time seeing what its connected to, but it looks like its connected directly to the endlink?? am i seeing that right??
OP, what year and make is your car? where did you get it from? and can you post those part numbers on the item i have circled in red. I see your from Scotland?
- J
Old Aug 15, 2008 | 12:08 PM
JasonZ-YA's Avatar
JasonZ-YA
Has to be some sort of spring loaded torque damper for the sways...
then again, the part circled in red looks to be a completely sealed electrical unit of some sort? like to measure/record movement?
Old Aug 15, 2008 | 12:58 PM
Colin_S's Avatar
Colin_S
No don't have RAS and it doesn't seem to have anything to do with alignment. It is only on one side.
Don't know either, trying to find out.
It's a UK car so my not be in the US spec
Yea it;s OEM, i've had the car from new and not added it.
Yea it's bolted onto the endlink after the sway bar on the (US) driver side
- J
It's an 07 HR and it's a UK car, i will try and read the numbers tomorrow.
It does not seam to be mounted in a way that it would effect anything the sway does.
Old Aug 15, 2008 | 01:07 PM
Z1 Performance
Former Sponsor
perhaps something VDC related
Old Aug 15, 2008 | 04:05 PM
JasonZ-YA's Avatar
JasonZ-YA
thats what i was thinking!
if not the only other thing i can think of is: a angular acceleration sensor....to measure when turning..maybe their ecu is different?
- j
Old Aug 15, 2008 | 04:08 PM
JasonZ-YA's Avatar
JasonZ-YA
lol...whatever it is I WANT IT! I GOTTA HAVE IT!
OP, SELL IT TO ME!
THATS NOT JDM TIGHT YO! ----- THATS UKM TIGHT!
lol...j/k
Subscribing to find out what it is...
Old Aug 21, 2008 | 06:09 AM
My350P's Avatar
My350P
Bump for resolution!
Old Aug 22, 2008 | 06:21 AM
shakuya88's Avatar
shakuya88
bump for unknown part
any ideas yet on this?
Old Aug 22, 2008 | 06:27 AM
shakuya88's Avatar
shakuya88
- J
just looking through everything again. it seem like part # 56271 is a different part on the mystery part car. That is the part where said mystery part is but it looks different from pic of car to parts break down. Maybe, just maybe it's a G part that got fitted to the Z for some reason or another. I'll check parts break down of RSU for G
Old Aug 22, 2008 | 07:42 AM
terrasmak's Avatar
unplug it and see what happens
Old Aug 30, 2008 | 11:05 AM
Colin_S's Avatar
Colin_S
Ok part numbers
6PM 008 043-76
6PM 008 591-76
CD700
101106
H02 S0711
Old Aug 30, 2008 | 12:25 PM
citymunky's Avatar
citymunky
That's not a G part, I don't have that either.
Bump to find find out what that is.
Old Oct 13, 2008 | 11:26 AM
Colin_S's Avatar
Colin_S
Anyone figure out what this is? It doesn't fit on my new end links so had to bolt it to one of the spare holes on the sway. Really need to understand what it does.
