Confused!
Old Nov 17, 2008 | 04:46 PM
my350isblack's Avatar
my350isblack
Default Confused!
So, i just changed my front brake pads, and when i turned the car on to take it around the black, the "VDC off", SLIP, and parking brake light are on. Even when the parkling brake is off the light is still on. I dont know why that would happen...
Old Nov 17, 2008 | 04:53 PM
surfcity40's Avatar
surfcity40
check your brake fluid..and I'm not going to tell you again.
Old Nov 17, 2008 | 05:01 PM
my350isblack
brake fluid is right below the max line, i bled them properly and everything. its not the first time ive changed brake pads, but it is the first on the Z, but everything is put back how its supposed to be. so i dont know whatsup with it
Old Nov 17, 2008 | 05:33 PM
350Zin'L.A.'s Avatar
350Zin'L.A.
for ur parking break, this is not a joke, but tring driving in a wide street, for ur saftey make sure theres no cars, and go about 15 miles and jus pull the e brake, and take it off, the light would go off... im guessing it will work, cuz my frend had a problem with the his rpm, it was stuck on 2000 and he downshifted not too hard but it moved again..
Old Nov 17, 2008 | 05:43 PM
my350isblack
i guess ill try it. ill let you know if it works tomo
Old Nov 17, 2008 | 05:48 PM
DavesZ#3's Avatar
DavesZ#3
Wait - did you only change the front pads or did you do that plus bleed the brakes?
Changing pads shouldn't cause the lights to come on unless you let the fluid get low. Since you claim that didn't happen, then it's not low fluid. Chances are that you damaged or disconnected one of the wheel speeds sensors or cables while changing the pads.
Old Nov 17, 2008 | 05:52 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
....and how would the parking brake have ANYTHING to do with the front brakes?
Old Nov 17, 2008 | 06:00 PM
my350isblack
yea i only changed the front and bled them, the fluid did get low after i bled them and then i filled it back up, and the only "cable" i moved was the brake line, i didnt touch anything else
Old Nov 17, 2008 | 06:01 PM
my350isblack
it doesnt, i just thought i would give it a try. i hate seein those lights come on
Old Nov 17, 2008 | 06:15 PM
TreeFiddyZee
Do WHAAAAT!?
I don't know if this would do anything, but did you try and disconnect the battery for awhile and reconnect?
Old Nov 17, 2008 | 06:25 PM
my350isblack
i havent tried it. but i will, possible stupid question butttt, that wont harm anything else right????
Old Nov 17, 2008 | 07:25 PM
TreeFiddyZee
Do WHAAAAT!?
It shouldn't. It'll reset your stereo to default settings, but I don't really think it'll cause "problems". You have to do this when you're doing anything electrical anyway. i.e. installing a new stereo, etc.
Old Nov 18, 2008 | 09:27 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
You're willing to drive down the street and pull up the e brake but you're scared that taking the battery cable off will hurt something?
Old Nov 18, 2008 | 10:52 AM
my350isblack
^^i enjoy sliding the car but thanks for all the feedback but while i was on my way to work this morning they all went off at different times, so no more lights on... its weird but o well
Old Nov 18, 2008 | 12:43 PM
TreeFiddyZee
Do WHAAAAT!?
In most cars, if a code is thrown, the light comes on. If the condition doesn't repeat, then the lights go out after a certain number of startups. Glad to hear the lights went out.
Old Nov 18, 2008 | 02:20 PM
my350isblack
Thank you sir. me too
lolwatbro
Oct 9, 2021 04:58 AM
ddegrande21
Sep 6, 2015 11:15 AM
GettinOnIt
Aug 18, 2002 07:35 PM
bigtul4u
Jun 16, 2002 03:56 PM
