Brembo and Base Brake Questions
I was hoping someone could lend some help with a question I had. Here's the situation.... I own a 2006 base model 350z, thus base brakes. My friend owns a 2004 G35, loaded with brembo brakes. He's actually planning on trading it in to a dealership, who doesn't care what kind of brakes are on the car, as longs as they work! Therefore, he's interested in switching brakes... which I'm pretty excited about. I've done some research and have a pretty good idea about what is expected to upgrade my 350z to these brembos. But, does anyone have any information on problems there might be switching the Brembo-equiped 04 G35 brakes to brakes from a base 06 350z? I don't imagine there will be any issues, but wanted to see if anyone might think otherwise.
Any insight would be great!
From what i could see from looking around this forum, it is a painless swap. Brembo caliper bolts will be needed and dust shield will have to be trimed or removed.. Please correct me if im wrong as im also looking to do this too. I wish i had a friend handing over brembos before they traded it in...GL with swap!
I know it's possible because I own a G that currently has base brakes, but once upon a time had Brembos.... but am not sure what all the job entailed.
You should install new brake pads and check the rotors to determine if they are still true (i.e. not warped). You can have the rotors turned provided they were not turned previously. Also, it a good time to change the brake fluid. I changed my brake fluid to DOT 4 (its blue instead of yellow - DOT 3) so you can see that the new brake fluid is replaced to all the calipers.
Make sure you torque the caliper bolts to spec (see Nissan Service Manual for details). Bed in the new pads per manufacture direction.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
