KW Hydraulic Lift System
Old Nov 26, 2008 | 08:19 AM
Chebosto's Avatar
Chebosto
Default KW Hydraulic Lift System
http://www.kw-suspension.com/en/30_P..._HLS/index.php
KW HLS (Hydraulic Lift System)
helping sport cars avoid road clearance difficulties
Raises the vehicle up to 45 mm
The HLS provides additional road clearance for lowered vehicles. When expanded, a range of 30mm to 45mm of lift is produced, thereby helping sport cars avoid road clearance difficulties like speed bumps, road constructions etc.
Version HLS 2
HLS 2 which enables only the front axles to be lifted and lowered
Version HLS 4
HLS 4 covers both the front and rear axles of the vehicle
- For vehicles with with little road clearance
- Vehicle specific applications
- Activation of change in height by a small keychain transmitter
avoiding the need to run additional wires through the vehicle
- Height changes can be done while the vehicle is moving, up to speeds of 50 mph
- Automatically lowering of the vehicle
- With TÜV certificate
- Rubber bellows protect hydraulic cylinder, thereby providing long term durability
The hydraulic cylinder unit is installed between the spring perch and spring. The pump unit is installed inside or near the spare wheel well. A programmable control unit processing the CAN Bus signal for speed control is also included in the kit.
HLS Kits are offered in 3 configurations:
1. HLS conversion kit with shorter springs to adapt to existing KW coilover
2. HLS conversion kit with lowering springs for OEM coilover kits.
3. Complete KW coilover kit with HLS adapted to it.
Think: aragosta air cups.
http://www.kwsuspensions.de/HLS-Special/video.html
they're not out yet for any KW coilovers for the Z application....
Old Nov 26, 2008 | 09:59 AM
enuff4life's Avatar
enuff4life
can we change it while we are driving low speed?
Old Nov 26, 2008 | 10:02 AM
Chebosto's Avatar
Chebosto
it has speed monitoring control so you can change the ride height while driving ..
Old Nov 26, 2008 | 10:36 AM
24v GTI Guy's Avatar
24v GTI Guy
i shutter at the idea of how much that is going to cost
Old Nov 27, 2008 | 08:27 PM
Nate76s's Avatar
Nate76s
Would be nice if it was cheaper than the Topsecret Roberuta Cups.
Old Nov 27, 2008 | 09:42 PM
IIQuickSilverII's Avatar
IIQuickSilverII
is the rear KW coilover true coilover? if so this must be $$$
otherwise most likely its going to be a case similar with the top secret ones that you can only do them in the front.
Old Nov 28, 2008 | 09:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it's not going to be out for the Z
Old Dec 1, 2008 | 02:50 PM
dphoenix's Avatar
dphoenix
that would be very helpful parts!
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
