What did you have to remove? it seems as if I am going to have to cut or remove part of the plastic under panel to make this fit. also the control arm bolts seem as if they have to come out instead of removing a nut you must remove a bolt?
there is a piece of the under panel that either needs to be cut or removed before I can install the brace...it wont fit if this piece is not cut or remove.......did no one else run into this problem?
correct, since you have the newer version which is meant to clear the larger aftermarket oil pans/spacers
I had to take inff due to the APS oil pan. So they have a new one huh
Just another point that no matter what you have, something better will come along..
