KW ride height range
Old Jan 26, 2009 | 07:56 AM
heyitzalex's Avatar
heyitzalex
Default KW ride height range
The KW site adverties the V1/V2/V3 as having a max drop of around 1.5in on a 350z. However, a vendor here advertises the coilovers saying that they are able to go as low as 4in on a Z. Which one is correct?
Old Jan 26, 2009 | 08:14 AM
warmmilk's Avatar
warmmilk
i'd go with the manufacturer's figures as they designed it, not some guy trying to make more sales...
Old Jan 26, 2009 | 08:44 AM
kelsey_kaye's Avatar
kelsey_kaye
Honestly I don't really believe either.. 1.5" sounds too small and 4" sounds a bit too much. Who was the dealer?
Old Jan 26, 2009 | 10:56 AM
evil_tt's Avatar
evil_tt
I have the option of about a -2.5" drop on KW2
Old Jan 26, 2009 | 12:42 PM
terrasmak's Avatar
Why get great coilovers if you want to lower your car to the point of not having any up travel.
Old Jan 26, 2009 | 12:43 PM
zettahertz's Avatar
zettahertz
But it seems like it can only has 1" of adjustment between max and min just by looking at the rear adjustment ****.
Old Jan 26, 2009 | 12:45 PM
blasian's Avatar
blasian
I've dropped my V3s maxed in the rear and I had no wheel gap at all. If I had to guess it was probably about 2.5"
Old Jan 27, 2009 | 10:17 PM
Gsedan35's Avatar
Gsedan35
When your dealing with a honest manufactuer AND one that does it's engineering, you will not see big differances between min and max drops on setups that adjust height via spring preload. What Kw publishes makes sense. Being able to squeez a extra mount of drop below what they publish might be possible, but Kw's engineer's don't think it's good idea or they would have included that much drop in their specs.
On the whole, if 1.5" isn't enough chaulk it up to not having don the reasearch you should have before you bought.
Old Jan 29, 2009 | 09:21 AM
kelsey_kaye
Uh... thanks, but I didn't buy these.
Old Jan 29, 2009 | 09:33 AM
blasian's Avatar
blasian
KW V3's has a TAV (I think that's it ) range of 1.5" drop but I'm sure it drops lower than that because I accidentally slammed mine
Old Feb 3, 2009 | 07:59 PM
zettahertz's Avatar
zettahertz
seems like it can drop pretty low now that i see this...
http://www.myg37.com/forums/brakes-a...view-look.html
Old Jun 22, 2010 | 07:33 PM
DaProdigy's Avatar
DaProdigy
glad i found this thread.... puts my concerns to rest on K-dubs' lowing capabilities
416blueZ
Jun 11, 2024 10:56 AM
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
