creaking
Old Jan 30, 2009 | 02:08 PM
03Zilverstone's Avatar
03Zilverstone
Default creaking
I've recently started hearing a creaking noise coming from the front of my '03. I'm not positive, but it seems to be the driver's side. It mostly does it while entering a stop or accelerating from a stop. It also does it at times on slow speed bumps.
Old Jan 30, 2009 | 03:45 PM
THe Emperor's Avatar
THe Emperor
I got the exact same thing and searched tons of topics and counldn't find out what it is. It gets on my nerves. Drivers side on low speed bumps just like you said.
Old Jan 30, 2009 | 03:46 PM
03Zilverstone
What's your year and milage? I'm at a tick over 60K. The only thing that I can think of is a bad strut.
Old Jan 30, 2009 | 03:47 PM
terrasmak's Avatar
endlinks and sway bar bushing can also cause this.
Old Jan 30, 2009 | 03:49 PM
THe Emperor
Originally Posted by 03zilverstone
what's your year and milage? I'm at a tick over 60k. The only thing that i can think of is a bad strut.
04.5 45,500
Old Jan 30, 2009 | 03:50 PM
03Zilverstone
Being loose or going bad?
Old Jan 30, 2009 | 03:54 PM
terrasmak's Avatar
going bad for wither one. Grease could actually help the sway bar bushings.
Old Jan 30, 2009 | 03:59 PM
Gsedan35's Avatar
Gsedan35
Compression rod bushing
Inner lower control arm bushing
swaybar bushing what once was lubed, but really isn't anymore
Old Jan 30, 2009 | 04:03 PM
03Zilverstone
Thanks for the help guys. I think I'm going to pull the sway bar sunday and check out the links and lube up the bushings, since I always prefer to start with the cheap/free solutions. If the links are bad I should be able to feel play or roughness in the ball/socket, right?
Chebosto
Sep 18, 2006 10:52 PM
mixedup
Sep 15, 2004 05:39 AM
cedusett
May 11, 2004 10:53 AM
Z CRUZN
Apr 27, 2004 07:49 AM
danotto
Jan 20, 2004 11:20 AM
