Cracked bushings on compression arms?
Old Jan 30, 2009 | 04:11 PM
pchio's Avatar
pchio
Default Cracked bushings on compression arms?
Hi guys, anyone have the problem on crack bushings on the front compression arms? (the arm pointing to the rear, (to the right in the pic)) I believe these cracked bushings are causing my Z to be unstable during hard braking condition and my caster is a little bit off at this time. I know there was a TSB on G35, but i couldnt find anything on the Z.
I called Nissan and they told me that they dont sell the bushings alone, only the whole arm ($179 retail each, ouch!) Anyone knows anywhere sell them or any possible aftermarket upgrade, like adjustable front caster arm? Thanks!!
Old Jan 30, 2009 | 04:19 PM
pchio's Avatar
pchio
Just found an Infiniti part # for these bushings:
54570-AC70A
Hopefully they will fit the Z, anyone knows?
Old Jan 30, 2009 | 05:18 PM
terrasmak's Avatar
Nismo has some i believe 54560-RRZ30
http://www.mynismo.com/products/?id=5348 i could be wrong, but i think these are them
Old Jan 30, 2009 | 09:10 PM
Gsedan35's Avatar
Gsedan35
While that sort of looks like the compression rod bushing, it isn't. It's the rear radius rod bushing. Nismo makes the lower innner control arm bushing, not the compression rod bushing.
Old Jan 30, 2009 | 09:12 PM
Gsedan35's Avatar
Gsedan35
54570-AC70A
I find it really hard to believe that the Z would use a different bushing at that spot. I just did the bushing install on my car 2 day's ago. So much more cost effective then the new arms.
Old May 17, 2009 | 06:16 PM
sammyG350gt's Avatar
sammyG350gt
when I installed a Noltec lower control arm bushing my friend noticed my compression arm bushing is cracked... It's not to the point where it's noticeable while driving but I'm sure it's just a matter of time.
does anyone know if there's an aftermarket bushing for this? I dont think Noltec makes one.
and yes all of the 350z/G35 bushings are the same.
Old May 19, 2009 | 08:23 PM
sammyG350gt
bump.. somebody on here has to have changed there compression arm bushings by now. did you just replace the entire arm??
Old May 19, 2009 | 09:47 PM
mthreat's Avatar
mthreat
First time, I replaced the whole arm. Then I bought the part number 54560-RRZ30, which is the front lower transverse link bushing:
http://www.mynismo.com/images/?id=5801
Next time my bushings tear, I'll install the nismo ones.
Old May 20, 2009 | 07:05 PM
sammyG350gt
^- is that bushing for the lower control arm or the compression arm?? (looks like control aim)
none of the bushings on mynismo say they are for either arm...
Old May 20, 2009 | 09:19 PM
mthreat's Avatar
mthreat
Nissan calls it the "Transverse link" in the service manual. This image from SPL parts' website calls it the "front lower arm", and this should be the bushing that connects the front lower arm to the front crossmember.
From http://www.splparts.com/main4/parts/...tmultilink.htm
Old May 22, 2009 | 03:20 PM
sammyG350gt
i found the front lower arm bushings from Noltec. The bushing I need is the outer one on the compression rod in that diagram
Old Aug 30, 2011 | 09:40 AM
350zACCHAN's Avatar
350zACCHAN
54570-AC70A
I'd like to know the same. Has anyone used this to replace their bushings? From what I hear the bushings can be purchased by themselves for the G35 sedan but the coupe and 350Z need to have the enitre arm replaced. Any confirmation?
Old Dec 15, 2012 | 11:39 PM
350zACCHAN's Avatar
350zACCHAN
Very old topic but in case anyone is having this issue, I was able to use the Infiniti bushings. The hole was a bit smaller, but the shop I went to was able to shave the hole slightly to make it work.
It's been over a year since I've had this done and there has been no issues.
I got mine done at West End Alignment in Gardena, CA. I highly recommend them.
Twenty4
Jan 17, 2016 01:20 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
CJs_Z33
Sep 18, 2015 12:06 PM
