Tein S-techs - ??
Old Mar 25, 2009 | 01:39 PM
tollboothwilley's Avatar
tollboothwilley
Default Tein S-techs - ??
Will Tein S techs settle more than the .7 and .6 they are supposed to drop the car?
Old Mar 25, 2009 | 07:09 PM
o2sys's Avatar
o2sys
depends on the car there will be a tolerance range...but .7F .6R is about right
Old Mar 25, 2009 | 09:21 PM
Gsedan35's Avatar
Gsedan35
Having been a member here since the beginning in 2003, S-tech's are not known for sagging beyond their drop specs on the 350Z.
Old Mar 26, 2009 | 05:19 AM
o2sys's Avatar
o2sys
Its funny how stech are such a small drop...
S stands for style and these seam more performance oriented....
Old Mar 26, 2009 | 06:23 AM
ttuberz's Avatar
ttuberz
mine dropped a bit more than .7 and .6 i think up to an inch...ive had them for about 2 yrs
Old Mar 26, 2009 | 07:11 AM
350Speed's Avatar
350Speed
Are you still running your stock shocks with no problem? The reason I asked because I'm thinking to replace my stock springs with S-Tech.
Thanks.
Old Mar 26, 2009 | 07:12 AM
tollboothwilley
I've heard from some people that it dropped closer to 1.5" overall...after a year or two...
Old Mar 26, 2009 | 07:31 AM
o2sys's Avatar
o2sys
TEIN only has warranty against sagging for only 1 year
Old Mar 26, 2009 | 07:52 AM
VO...'s Avatar
VO...
Administrator
I've had mine for about 4 years. They haven't sagged beyond what they were suppose to...
Old Mar 26, 2009 | 08:26 AM
Gsedan35's Avatar
Gsedan35
link to owner comments posted here?
Old Mar 26, 2009 | 08:32 AM
Gsedan35's Avatar
Gsedan35
What is your point?
Old Mar 26, 2009 | 08:33 AM
ish06FairladyZ's Avatar
ish06FairladyZ
I've had mine for a little over 2 years now and they haven't sagged beyond what they were suppose to, shocks are still fine as well...
Old Mar 27, 2009 | 06:05 AM
ttuberz's Avatar
ttuberz
Thanks.
Yes Ive been running them with stock shocks the whole time and not a problem. I am going to order coilovers as soon as I make up my mind on which ones first and my s-techs will be up for sale if ur interested. PM ME
Old Apr 16, 2009 | 03:43 PM
yaro's350z's Avatar
yaro's350z
i have stock springs and shocks, if i get the s-tech will it drop the rear about an inch?
i would like to drop about 2 inches both front and rear.
should i just go with the springs?
Old Apr 16, 2009 | 04:23 PM
Get_Zwole's Avatar
Get_Zwole
quick 2 second search found this
Lowers: Front -0.7" Rear -0.6"
so if your going to go 2 inches doesnt seem like a good choice does it?
Old Apr 21, 2009 | 10:35 AM
yaro's350z's Avatar
yaro's350z
not at all, thanks.
Old Apr 21, 2009 | 02:09 PM
Peak350's Avatar
Peak350
S-techs are one of the better options for performance springs as far as I can tell though...
Old Apr 21, 2009 | 03:18 PM
kyx4n's Avatar
kyx4n
Just wondering, does the S tech affect ride quality at all?
Old Apr 22, 2009 | 12:59 PM
BlueDragonZ's Avatar
BlueDragonZ
Is everyone that are using S-Tech's gotten the camber/toe kits installed as well? From what I understand you don't really need the camber/toe kits unless you're dropping 1"+ am I wrong to think this? Btw I will be running 20" rims on Falken FK452.
Old Apr 22, 2009 | 01:14 PM
Peak350's Avatar
Peak350
If you have an 04.5+ then not too much, the revised rear spring rates are actually higher than the S-tech rears, the fronts are progressive, but most of the "progression" has occurred just from the preload in the strut and the weight of the car. The front rates are a bit stiffer than stock 386/314 IIRC, but nothing significant. Shocks will change ride quality more, and the drop itself will play a bigger difference.
In the rear you can play with the upper spring mount to change the drop (both directions).
Bodyboarder81
Nov 2, 2015 12:17 AM
failsafe
Apr 23, 2003 11:38 AM
robertchen
Nov 13, 2002 07:41 AM
