Wilwood vs Rotora BBK?
I have more than enough space for wheel clearance.
What is the height and width comparison of the pads used by the upgraded caliper when compared to the "factory wilwood kit"?
I measured the contact radius on my front rotor and it appears that 1.75" of the rotor's radius is used. From the pictures above, the upgraded pads look taller so that might mean 2.0" of pad height? or 2.0" of the rotor's radius is used in contact. Am I correct? Incorrect?
they look wider too but im sure its easier for u to tell me than for me to go pull the caliper & look @ the pad.
Adrian
Adrian
More rotor surface is covered however piston area is the same so overall clamping force remains the same as the smaller pad. About 15%+ longer life however. And some other bennies along with that.
No need to hut them down or wait, they are on our website here:
http://www.stoptech.com/tech_info/wheel_fitment.shtml
Thanks a lot.
seagrasser
Oct 11, 2015 03:27 PM
