Finally dropped!!!
Old Apr 26, 2009 | 08:45 PM
kyx4n's Avatar
kyx4n
Originally Posted by gsingh350Z
Ellington Field. Southeast Houston.
Ahh..
Thanks
Old Apr 27, 2009 | 12:40 PM
singh's Avatar
singh
_______________
Question
Originally Posted by pony_killer
gsingh if you wanna go for a ride id be more then happy to take you. i kid you not to me it feels just like stock. 5 is not the softest but its perfect for my needs
Few questions if you don't mind.
So is it easy to adjust the dampening? Like is there a certain tool you can use to adjust it without having to disassemble anything? And you say you have it on 5, so does that make it adjustable from 1-10, 1 being softest and 10 being hardest setting?
Old Apr 27, 2009 | 12:57 PM
tranceformer95's Avatar
tranceformer95
I had those same dampeners on my 350z, along with the matching tokico d-spec springs. Also had some hotchkis swaybars & SPL endlinks.
They're 7-way adjustable.
0 = stiffest
6 = softest
6 meaning # of (counterclockwise) turns from full stiff
They're adjustable with an allen key or the adjustment tool that's included. Rears can be adjusted by popping off the plastic rear cover on the rear strut tower bar. Drill a hole through the metal and then stick a long T-handled allen key and voila. Easy as that to adjust the rears. For the fronts just pop the hood.
I set it at "1" for a day or so, pretty uncomfortable (for me). Summertime I left it at "2" and winter time with snow tires I just left them at "3". When I went back to stock to trade in my Z, it felt about the same, but I could tell that the stock rear springs were stiffer than the Tokico springs.
They're a great bang for the buck suspension if you don't want/need coilovers.
Old Apr 27, 2009 | 01:08 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
0 = stiffest
6 = softest
I had a feelin in order to adjust the rear, the back strut tower cover needed to come off but didn't know you had to drill a small hole. All good, if i ever need to adjust it now I know what to do.
Old Apr 27, 2009 | 01:50 PM
tranceformer95
Sorry, didn't mean to hijack your thread. Just wanted to clarify that these dampeners are great for the $$$.
Old Apr 27, 2009 | 05:50 PM
singh's Avatar
singh
_______________
Hey with those Tokico dampeners and spring combo, did that lower your car any? Wouldn't that be a coilover setup then? Sorry I don't know that much about suspensions..
Old Apr 27, 2009 | 06:17 PM
tranceformer95
They're not coilovers, they're are spring and dampener set. The height is NOT adjustable, only the rebound/compression is adjustable. Spring rates are 375 front & rear. Drops about 1.25". Stock spring rates for 04.5+ are 314 front and 427 rear.
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
