My 06 Base shakes during braking
Old Apr 27, 2009 | 02:22 PM
50 Freak's Avatar
50 Freak
Default My 06 Base shakes during braking
Have a 06 Base, first owner...46K miles on it. About 30K of that is freeway.
Anyways, I noticed it started to shake whenever I applied the brakes. At high speeds (70+) I would really feel it in the steering wheel. Not so much on the brake pedal.
Called a shop, they said it was my rotors were wharped. Took it in and they resurfaced the front rotors and intalled some Hawk pads on the front.
Was okay for about 50 miles, now the shaking is back....not as bad this time, but progressively worse than from when I got it back last week.
Do you guys think it's the rear rotors? Or what.
Thanks for the advice.
50F
Old Apr 27, 2009 | 02:30 PM
ZForce1's Avatar
ZForce1
You're done son
They probably had to cut too much. 46K is a lot on a rotor these days.
I'd replace them if it were anywhere near the machine to limit, other wise you'll be dealing with it again.
Rear rotors would give you a pulsation more in the pedal and not the wheel.
Old Apr 27, 2009 | 02:31 PM
cdoxp800's Avatar
cdoxp800
Front Rotors are warped for sure
Old Apr 27, 2009 | 03:18 PM
NttnbutaZthang's Avatar
NttnbutaZthang
yup my 05 with 48k is doing the same thing...warped rotors it is
Old Apr 27, 2009 | 03:54 PM
50 Freak's Avatar
50 Freak
Man, they must not be making rotors like they used to. Warped at 46K is common??
Ge'ez, I can see it if I drive like an maniac...but I don't.
So who makes decent rotors that wont warp at 45K
Old Apr 27, 2009 | 04:17 PM
ZForce1's Avatar
ZForce1
You're done son
I don't know but, if you figure that out let me know
Old Apr 27, 2009 | 05:01 PM
kham25's Avatar
kham25
MY rotors just warped at 10,000 miles on my 2007. Imagine how i feel
Old Apr 27, 2009 | 05:28 PM
R350Zz33's Avatar
R350Zz33
i had rotor problems when i first got my z in july with 50 miles on it how do u think i feel
Old Jun 30, 2009 | 09:23 PM
brandon3434's Avatar
brandon3434
^^^^ my wheels fell off the car in its first mile, then the ground ripped away at my poor rotors...so i guess they were warped, then i got out, got a phone call, my whole family was murdered, then my distant family was all eaten by wilderbeasts...how do u think i feel
I r winner
Old Jul 1, 2009 | 07:03 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
could be any number of things
rotors too thin
torn/worn bushings
rotors don't really "warp" - they get deposits on them, usually from improper pad break in, using the wrong pad for the conditions under which you drive, etc.
Repeating the pad break in prodecude will generally get rid of it, unless the rotors are too thin in the first place, at which point, a replacement will be required
Old Jul 1, 2009 | 07:14 AM
JasonZ-YA's Avatar
JasonZ-YA
I r winner
Old Jul 1, 2009 | 12:09 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
rotors too thin
torn/worn bushings
You beat me to it.
350z82
Oct 1, 2015 06:25 PM
