Big Brake kit pedal feel?
Old Apr 28, 2009 | 09:57 PM
Chomorro's Avatar
Chomorro
Default Big Brake kit pedal feel?
I have this big brake kit http://www.essentialgears.com/tho/tr...T-3974246.html. My brake pedal with even the slightest pressure will stop the car. Do big brake kits normally have this effect? Its hard to come to a stop smoothly because the pedal is so much higher. I bought my 350 with it installed.
Old Apr 29, 2009 | 01:25 AM
Z04's Avatar
Z04
wait until you have to actually step on the brake hard. you might find your teeth on the windshield after they shoot out of your mouth.
seriously though, that can be expected with a BBK, they are larger and have a lot more stopping power than OEM.
Old Apr 29, 2009 | 02:25 AM
0jiggy0's Avatar
0jiggy0
Just somethim youll have to get used to.
Old Apr 29, 2009 | 04:07 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
I have the same problem also, can it be adjusted?
Old Apr 29, 2009 | 05:15 AM
huyrua's Avatar
huyrua
I'll trade my brembo for yours BBK.LOL
Old Apr 29, 2009 | 05:22 AM
Z04's Avatar
Z04
yeah, go back to OEM brakes. seriously though what did you expect by adding a BBK if not to stop better? it just takes some getting use to that's all
Old Apr 29, 2009 | 05:27 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
what pads are in it? take em out, snap some pics and note any #'s printed on the back side
Old Apr 29, 2009 | 06:27 AM
na_350z's Avatar
na_350z
I have the 4 pot Rotora BBK and that was my initially reaction the first time I hit the brakes. I was use to the OEM brakes. I got use to it already though.
Old Apr 29, 2009 | 06:59 AM
terrasmak's Avatar
me too, but it only happens with the one set of pads. My other pads feel just like normal brakes. I suggest Wilwoood BP10 pads, or EBG green.
Old Apr 29, 2009 | 09:22 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
That would very likely be a sympton of oversized caliper pistons leading to a very front baised condition or extremely high bite pads. A good indcator of this would be to see how easy it is to get into front ABS activation...the easier it is, the more front biased you are. The only "adjustment" would be to install very low bite pads to offset the effect or change out to calipers that have piston sizes more in the range that matches the stock parts.
Old Apr 29, 2009 | 09:41 AM
uglyduc's Avatar
uglyduc
^^ +1
Replace your pads with something that has less bite.
Quick story, same case different ride, I have SBK brakes on my SS Ducati, ductile iron rotors and carbon fiber rims, my old pads would stoppie her if I breathed on the brake lever, switched to a higher heat CF pads which didn't have as much initial bite but would increase as the pads heated up and didn't feel like i was peeling up pavement with my front wheel when I braked and had better brake modulation. Sounds like you have the same issue.
Old Apr 29, 2009 | 10:16 AM
Spork's Avatar
Spork
I'll trade you my full stock system for it.
Old Apr 29, 2009 | 11:00 AM
redlude97's Avatar
redlude97
A properly designed BBK should have similar levels of pedal travel compared to stock to allow for adequate modulation ability. BBK's that have little pedal travel are not sized correctly and are using pistons that weren't chosen correctly for the application. This is pretty common with some BBK manufacturers who don't do R&D work and just make an adaptor to fit a generic caliper to a rotor for a vehicle.
Old Apr 29, 2009 | 11:43 AM
uglyduc's Avatar
uglyduc
My pedal travel changed also from switching from rubber to SS lines. Of course that has less to do with rotor/pad sizing and more to do with brake line expansion, but thought I'd mention it because it was noticable.
Old Apr 29, 2009 | 12:42 PM
Chomorro's Avatar
Chomorro
Wow excellent replies . My car needs the brakes because it is turbocharged, i was just curious if it the pedal could be adjusted to have a little more give. You answered my question though, as soon as the pads go, i will look into the brands you have mentioned. I am also running stainless lines i believe too. Sorry i just bought the car and im learning what all it has on it .
Old Apr 29, 2009 | 09:58 PM
JETPILOT's Avatar
JETPILOT
Turbocharging doesn't require new brakes. Track driving or Auto-X is where you will need new brakes.
Jambo016
Sep 16, 2016 01:08 PM
samansharif
Sep 25, 2015 12:31 PM
