Vdc and slip light
Mine came on randomly about two days ago...04' Nismo S-tune Z33...started the car drove around and the VDC/SLIP lights were on, went into the grocery store, car was off for 15min or so, got back in turned it on, no lights at all, havent seen them since. I just had the car in for maintenance and have lots of tread on tires, lots of brake pad, and brake fluid is topped up, no work was done on brakes/susp/wheels...my advice is wait and see if the lights goes off....but if warning lights make you paranoid go get it checked...
ok guys the lights are still going on checked the breaks they seem to be warned out in the back so im going to change those this weekend. i hope thats would take care of it.
I'm 99% positive its your pads and/or rotors. The same thing happened to me at about 45k miles. I changed the pads and noticed the rotors were worns so I changed them too. Then everything went back to normal. Also, be careful when those lights are on, it means your VDC will not be working. So dont get crazy on wet roads and taking corners. *Speaking from experience*
ok
question
I had this problem and i decided to dig into the problem as well
I replaced my CPS in sept
I replaced my Brakes, bleed the fluid, and rotors look fine
No codes on my OBD2
no performance is lost.....weird?
question
No codes on my OBD2
ok guys good news. the vdc and slip light came off. i had the car realigned again and it hasnt come back on since then.
i guess i can make it to the san marcos meet this weekend. well i hope i can.
