Lowering Springs Picture Thread
Old Aug 30, 2009 | 07:56 PM
  #61
jduet's Avatar
jduet
Originally Posted by 08nogaroZ
anyone have GF210's without the rear mod and without camber kits? any alignment problems? such as too much negative camber? considering these springs and I would really appreciate the info.
thanks
You will have too much negative camber in the rear even without the springmount mod. It's not too bad with just springs but you will want to get it corrected when you start to see that camber wear.
Old Sep 7, 2009 | 04:00 PM
  #62
Imnu2dis's Avatar
Imnu2dis
Default Hotchkis Stage 1
1 week on the Hotchkis Stage 1. Stock wheels with no spacers. Tires: F 245/45-18 R 255/45-18
Old Sep 12, 2009 | 06:02 PM
  #63
jammin's Avatar
jammin
thanks
I know every car is different, but I personally didn't have to purchase a rear camber kit. Well I did purchase it, but sold it because I ended up not needing one. If anything, my front tires wear faster than my rears.
Old Sep 12, 2009 | 08:36 PM
  #64
o2sys's Avatar
o2sys
S-techs w/ rear springmount mod:
Old Sep 13, 2009 | 04:14 PM
  #65
armintheman's Avatar
armintheman
hey guys what are the best springs to use that will let me keep my stock shocks and not use a camber kit? s-tech? i want a nice drop but not to an extreem because i have a STEEP driveway. i was between tein and prokit figure they dont even drop the car a full inch.
Old Sep 13, 2009 | 04:32 PM
  #66
o2sys's Avatar
o2sys
go with S-techs i clear driveways and crappy NYC roads just fine...
Old Sep 13, 2009 | 09:50 PM
  #67
jdhuegel1's Avatar
jdhuegel1
There's a sideview pic of mine in this thread:
https://my350z.com/forum/exterior-an...rom-paint.html
I'm on Eibach Sportlines
Old Sep 15, 2009 | 09:07 AM
  #68
armintheman
cool so s-tech but do i need camber kit for that?
Old Sep 19, 2009 | 07:24 PM
  #69
Anomaly's Avatar
Anomaly
Originally Posted by nismonian
more pics of prokits?
Give me a week and I'll take some new pics of my recently installed Pro-Kits with D-Specs.
Old Sep 20, 2009 | 08:05 AM
  #70
armintheman
i think prokit would be best fit for me. no camber kit for a prokit?
Old Sep 20, 2009 | 09:04 AM
  #71
Anomaly's Avatar
Anomaly
I went with the rear SPC camber kit and had it all installed at the same time. I can't really say yes or no because I won't have alignment specs after the pro-kit install without the rear camber kit.
Old Sep 20, 2009 | 04:25 PM
  #72
armintheman
ok gotya so no pictures yet?
  #73
Adrians07Z's Avatar
Adrians07Z
2007 Touring - Tein S-Tech
I love the way it sits now .. not too low and should be able to get the alignment back in spec .. rides a little smoother on regular bumps yet is firmer around corners / doesn't drop or raise as much braking and accelerating
the sun threw a shadow on the wheels .. but you can make out where the top of the wheel is .. just follow the edge around .. I'll get a better pic when I wash it this week (car is dirty and just installed the springs last night)
Old Sep 21, 2009 | 05:54 AM
  #74
idrive_MD's Avatar
idrive_MD
an updated picture, still on the cobb springs and tokico d-specs:
Old Sep 21, 2009 | 11:30 AM
  #75
Dr. Venture's Avatar
Dr. Venture
i think you can go just a tad lower and still be in alignment spec...long as you have a rear camber kit.
Old Sep 21, 2009 | 06:35 PM
  #76
Anomaly's Avatar
Anomaly
Alrighty, here's my set up:
Eibach Pro-Kit Springs
Tokico D-Spec Shocks
SPC Rear Camber/Toe Kit
Enkei RPF1 - Fr: 19x9 +18 w/245/35/19, Rr: 19x10 +22 w/275/35/19
Stock suspension to give an idea of where my Z started at:
Measurements (wheel center-ish to fender):
Passenger Front - 16-7/8"
Passenger Rear - 18"
Driver Front - 16-5/8"
Driver Rear - 17-3/4"
After (pics outside of garage are on uneven ground):
Measurement (wheel center-ish to fender):
Passenger Front - 16-1/4" (5/8" drop)
Passenger Rear - 16-7/8" (1-1/8" drop)
Driver Front - 16" (5/8" drop)
Driver Rear - 16-5/8" (1-1/8" drop)
Decently consistent drops front and rear. Will be measuring about 1x per week over the next two months to observe "settling", if any.
I suspect the height differences between driver vs. passenger sides might be due to the manufacturing tolerances of the sheet metal.
Alignment Specs:
Left Front..........................Right Front
-1.43°..........Camber.........-1.66°
7.76°...........Caster............7.51°
0.04°.............Toe..............0.03°
Left Rear..........................Right Rear
-1.60°..........Camber.........-1.62°
0.10°...........Caster............0.10°
Not as aggressive nor as low as some on these forums, but my Z is my DD and I needed it to be street friendly.
Just a special thanks to Steve and Nima at Corner3 Garage for their excellent work installing and helpful advising on selecting my set up.
Old Sep 25, 2009 | 09:08 PM
  #77
fairl80z's Avatar
fairl80z
^^^ it can't be 16-16 5/8. I just measured mine and F are 13 1/4 and R are 14.
My set up:
eibach pro kit
eibach rear camber/toe kit
stock shocks
advan rs 18x10+25 all corners
Old Sep 25, 2009 | 09:21 PM
  #78
M1r4cL3's Avatar
M1r4cL3
RS*R Linear Springs w/ rear spring mounts cut < 1/2".
17x10 5zigen Fn01r-c Hot Version. 275/40/17 tires x 4.
Old Sep 26, 2009 | 06:22 AM
  #79
fairl80z's Avatar
fairl80z
^^^ nice my favorite color what offset are you running on those bad boys???
Old Sep 26, 2009 | 08:57 AM
  #80
Anomaly's Avatar
Anomaly
My set up:
eibach pro kit
stock shocks
I said about wheel center-ish. I measured from the edge of the bowl that all the lug nuts go into on the rims because that diameter is not going to change before/after the drop.
