brake calipers click
Old Jun 13, 2009 | 09:32 PM
derangedtoolman's Avatar
derangedtoolman
Default brake calipers click
So this is what happens:
after the car has been sitting for a while, and I start driving it, I hear the rear brakes click a couple times when i brake. but after a couple times of braking they dont click anymore. Anyone else have this problem? any help would be appreciated. thanks
Old Jun 13, 2009 | 10:52 PM
abeklipse's Avatar
abeklipse
Same thing happens to me. Don't know what causes it tho.
Old Jun 14, 2009 | 02:30 AM
Evilmexicaninus's Avatar
Evilmexicaninus
I don't think it coming from the brake calipers or rotors, it could be your rear axles.
Old Jun 14, 2009 | 03:10 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
It happened in my car also, but it wasn't the brakes. It's the rear axle clicking problem. There is a TSB to fix it. Here's a link that I set up with the sheet from Nissan.
http://files.me.com/brianpmurphy/0b30e1
Old Jun 14, 2009 | 09:33 AM
derangedtoolman
i got the rear axle click fixed already about a year ago, and it was a much quieter sound and that happened when i was moving from a stop. This distinctly happens right when i step on my brake pedal, and only happens at most 2 or 3 times.
any other ideas?!?!?
Old Jun 14, 2009 | 10:18 AM
TreeFiddyZee
Do WHAAAAT!?
From my understanding, the axle click can re-occur. Especially if the didn't follow the TSB to the letter.
Old Jun 14, 2009 | 10:41 AM
derangedtoolman
will they do the work again for free? my car is not under the 3 year guarantee anymore
Old Jun 16, 2009 | 08:31 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
This is a very common occurence with the brakes, especially the OEM Brembos. The pads will shift in the calipers, especially when going from reverse to forward. Pretty much all of the cars with OEM Brembos do this, 350Z, STi, EVO, etc since the pads are really just hanging from the pins at the top of the caliper. Some standard sliding calipers will also do this and a lot of it is down to the brake pad backing plate and how close it is to spec.
Not saying this isnt the axles but brake pad shift is a very common cause for this.
Old Jun 16, 2009 | 09:02 AM
Tac-M's Avatar
Tac-M
^ +1 my ap are the same way.
Old Jun 16, 2009 | 09:06 AM
Goku350z2007's Avatar
Goku350z2007
i have the same problem after replacing my brake pads with hawks
Old Jun 16, 2009 | 12:14 PM
Tac-M's Avatar
Tac-M
i don't know how correct this is, but i assume that the reason high performance brake pads are made few millimeters shorter is to compensate for expansion that occurs when things get really hot.
Old Jul 6, 2009 | 08:53 PM
jschrauwen's Avatar
jschrauwen
Originally Posted by StopTechErik
This is a very common occurence with the brakes, especially the OEM Brembos. The pads will shift in the calipers, especially when going from reverse to forward. Pretty much all of the cars with OEM Brembos do this, 350Z, STi, EVO, etc since the pads are really just hanging from the pins at the top of the caliper. Some standard sliding calipers will also do this and a lot of it is down to the A pad backing plate and how close it is to spec.
Now this sounds more along the lines of what I was thinking about my front brake clicking. I installed new 350Z CD/SL rotors and 350Z Brembo calipers with new AMS pads. While going very slow forward and a I first apply the brakes I hear one single click. If I move forward again from that position and will not hear any more clicking - BUT, If I reverse and go slowly and depress the brakes I'll once again hear a single click.
I only get one click going in the same direction.
Although Erik says this is normal, does it also mean that I should not be concerned?
The rotors, calipers and pads were all installed less than 2 months ago. Aside from this clicking the brakes are working beautifully.
Old Jul 6, 2009 | 09:20 PM
AVmagneticZ's Avatar
AVmagneticZ
i picked up a set of used 350z calipers and new rotors and ferodo racing pads (frodo? ferodo? cant remember) anyways i get clicking from the brakes some randoms times when i brake as well so must be normal. never had this with oem base model brakes. im not to worried bout it.
Old Feb 19, 2011 | 06:02 PM
jray8's Avatar
jray8
it happens with base models, ask me how i know
samansharif
Sep 25, 2015 12:31 PM
