Massive understeer!
Old Jun 14, 2009 | 08:23 AM
iflyjets86's Avatar
iflyjets86
Default Massive understeer!
heres to story. Weeks ago it rained for about a week straight in FL, lot of roads got flooded and a lot of new potholes came up. I accidentally drove through one and popped my rear tire. so i got two new rear tires and mounted them. Now my car has massive understear. i used to take a certain turn at 80, now i can barely take it at 50mph without the slip indicator coming on and the front brakes activating. the car feels so slugish and not responsive. I took it to nissan and all the suspension parts looked fine. Would a simple alignment fix this? any help would be appreciated!!
Old Jun 14, 2009 | 09:19 AM
redlude97's Avatar
redlude97
sounds like your new rear tires have significantly better grip than your old front tires. Replace the front tires
Old Jun 14, 2009 | 12:15 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
put the car on an alignment rack and make sure 1. everything is in spec and 2. nothing is bent
Old Jun 14, 2009 | 09:51 PM
terrasmak's Avatar
Posts 2 and 3 are perfect. Both of them are likely correct.
Old Jun 15, 2009 | 03:23 AM
DavesZ#3's Avatar
DavesZ#3
What are the sizes of your front and rear tires?
Did you replace the rears with the exact same tire that was on it before?
Old Jun 15, 2009 | 10:25 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
+1 on post 2/3
Old Jun 15, 2009 | 08:26 PM
danimaldaisy's Avatar
danimaldaisy
It could be a damaged strut.....one bad strut can throw the entire car off!
Old Jun 18, 2009 | 07:22 PM
iflyjets86's Avatar
iflyjets86
thanks for the feedback! sorry it took so long to respond i was out of the country for work. Currently am running 265/30 19s rear and 245/35 19s front on volks sf challenges. I took the car to nissan all suspension parts look okay. I know in terms of motorcycles an old front tire and a fresh rear tire will give u "push" or understeer, but the fronts are in okay condition. id say 70% life left. i also replaced the rears with the same brand of the front which were what i ran previously. toyo t1r's. nissan tried to align the new tires but the car wouldnt fit on the rack...to low! which surprised me cuz it works on the gtr and i dont have the car tucked, just 1.5 rear and 2 inch drop in front. thank you everyone for the feedback keep the ideas coming!
Old Jun 18, 2009 | 09:43 PM
terrasmak's Avatar
Its not going to tuck as easy with to small of a wheel in the rear, but with that drop its not just lowered it fing slammed. Remember , you starter off with a low to the ground sports car, then dropped the hell out of it.
BTW you have the wrong rear tires on it. TCS/VDC should hate you.
Old Jun 19, 2009 | 11:39 AM
Lawn Dart's Avatar
Lawn Dart
Your tire pressure could be different then before.
Old Jun 19, 2009 | 07:43 PM
iflyjets86's Avatar
iflyjets86
really? i dont doubt that, i just ran the tires i had on it since i bought it. what size should i be running?
also the tire pressures are the same as previous tires which didnt give me issues before. thanks for the feedback guys!
Old Jun 20, 2009 | 04:15 AM
DavesZ#3's Avatar
DavesZ#3
It does, that's why he's getting Slip lights when turning at speed.
OP, read here....
https://my350z.com/forum/showthread....1&postcount=45
Brad4rdHay
Mar 27, 2003 06:57 AM
AndyB
Mar 9, 2003 07:35 PM
moab355
Jan 3, 2003 03:30 PM
3rdpower
Jul 15, 2002 04:17 AM
