BBK Advice
Old Jul 29, 2009 | 09:10 AM
lbk16's Avatar
lbk16
Yup. The RB Caliper does use a stock sized Z32 pad - that is what I was afraid of -- that although I have a decent sized rotor (13 inch), the caliper/pad is simply not large enough.
Old Jul 29, 2009 | 09:59 AM
Tac-M's Avatar
Tac-M
i would suggest sending an email to Mike @ jr@ctbrakes.com and getting a set of xp10 fronts and xp8 rears.
Old Jul 29, 2009 | 10:05 AM
scotts300's Avatar
scotts300
I'm afraid to ask you what the full RB set costs. I could have sold you a full set of Z32 calipers and rotors for super cheap! The 240SX guys love using the fronts. I do have some track pads for the rears (I bought STs for the front) if you are interested.
Old Jul 29, 2009 | 10:09 AM
lbk16's Avatar
lbk16
Its actually not that bad - I think I paid ~2800 for the kit. Although the RB calipers take Z32 sized pads, the calipers are not the same as Z32 calipers (which I have on my WRX). The RB Calipers are forged and super lightweight. The rears are completely different. Too bad you don't still have track pads for the front. Hidnsight is always 20/20 - if I had it to do all over again, I might not go the same route. I would probably pick up either the Akebono 370Z kit or a Stoptech kit for the front and a larger rotor kit for the rear. For now, I think I am stuck with removing my backing plates, crafting some ducts and hoping for the best -- its that or sell the kit.
Old Jul 29, 2009 | 11:05 AM
scotts300's Avatar
scotts300
The scary thing is that you are still on street tires, so you are putting a lot less demand on your brakes compared to one day when you put on a set of NT01s, Hoosiers, or the like.
My StopTech BBK for my Z32 was the second installed on a Z32 and the first track tested. Here we are at Buttonwillow in 2003. The guy with the red Izod is StopTech's co-founder and engineering-now-general manager, Steve Ruiz. At the time, I was working with Matt at StopTech as my technician, but Steve wanted to oversee the testing and the instrumentation directly to monitor knockback. Those were some good times!
Attached Thumbnails BBK Advice-scotts94z32stinstrumentation.jpg   BBK Advice-scotts94z32stinstrumentationgregrob.jpg   BBK Advice-scotts94z32stinstrumentationgregruiz.jpg
Old Jul 29, 2009 | 12:32 PM
lbk16's Avatar
lbk16
Agreed. I definitely have some concerns about the kit long term. The Direzzas are pretty close to a track tire.
Old Jul 29, 2009 | 12:57 PM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
You should still start with a good set of pads and go from there. If your pads dont have an adequte temperature range you will be able to overheat them fairly easily on street tires.
Old Jul 29, 2009 | 01:30 PM
lbk16's Avatar
lbk16
That's my plan. Going to go with the DTC60s, I think. Erik, if I wanted to use the DTC60s in the rear, do you have another suggestion for race pad up front? Say a Carbotech XP10? I have a huge range of pads to choose from for the front - but I am limited in terms of pads for the rear.
Old Jul 29, 2009 | 03:36 PM
StopTechErik
Go with DTC60 front and rear, should be just fine. I used to run Hawk HT10s front and rear in my STi with a 332mm front BBK and they were great. DTC60s are just the next generation of HT10s.
Old Jul 29, 2009 | 06:20 PM
thinking's Avatar
thinking
General rule is to avoid mixing pad brands.
Also, I hate to tell you, but you can get StopTech kits for a lot less than retail. When I was looking, the RB stuff was only a good deal when you compare MSRP to MSRP. I looked at the RB kits before I found out about the deals you can get on StopTech. Of course, StopTech prices have increased since I bought mine.
I doubt the backing plates will make that much difference, but it is good to hear that RB is working with you on the issue.
Old Jul 30, 2009 | 03:41 AM
lbk16's Avatar
lbk16
Trust me, I did look at StopTech. The 4 wheel kit was substantially more expensive than the RB 4 wheel kit. Maybe I should price the kit again.
Old Jul 30, 2009 | 04:21 AM
plumpzz's Avatar
plumpzz
A good alternative is the arizonazcar.com kit. Thats the one I'm going to get this month. Cheaper than both kits, uses a forged caliper, many many pad options and very cheap replacement parts.
Old Jul 30, 2009 | 04:25 AM
lbk16's Avatar
lbk16
Right, but you lose your parking brake.
Old Jul 30, 2009 | 04:41 AM
plumpzz's Avatar
plumpzz
As with all 2 piece rear brakes. Adding a hydraulic line lock costs 35 dollars. You can always purchace a rear wilwood kit (wilwood makes their own kits now) with a 1 piece rotor that retains the stock rear drum.
If you're racing on street tires, you dont really need a rear bbk. A good set of race pads on the stock rear will treat you nice.
Old Jul 30, 2009 | 05:12 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
not all 2 piece rear brake kits lose the parking brake
Old Jul 30, 2009 | 06:27 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I used to use the 4 piston ST fronts with PFC-01 and the 2 piston ST rears with DTC-70's on my twin turbo G with r-comp tires when I tracked my G. Never had a problem with fade. I'm sure the larger rotors made a difference, but the PFC-01's in front really helped as well. Along with almost everyone else on this thread, I recommend trying different pads before you give up on your current rotor/piston setup.
Old Oct 22, 2009 | 04:40 AM
lbk16's Avatar
lbk16
Thought I would bring this one back to life. I ended up removing the dust shields/backing plates in the front. I switched to fresh rotors (since my previous rings were trashed) and and Hawk DTC-60s all around. What a HUGE difference. I ran five, 20 minute sessions at Gingerman Raceway (www.gingermanraceway.com) and I experienced no fade whatsoever. The brake torque was amazing - so much better than the Racing Brake pads that I was using. In addition, I have plenty of meat left on the pads. Looks like I will be keeping my Racing Brake setup for the time being. I have suggested that Racing Brake make it clear on its website and in its materials that for track use the dust shields/backing plates be removed to allow for maximum air flow.
Old Oct 22, 2009 | 02:52 PM
  #38
sluggoZ's Avatar
sluggoZ
I appreciate your follow-up. Thanks!
liqalu04
Jan 2, 2022 12:58 PM
seagrasser
Oct 11, 2015 03:27 PM
