Brake squeel
Old Aug 5, 2009 | 03:52 PM
dmroberson's Avatar
dmroberson
Default Brake squeel
Ok, so I'm driving, everything is fine. all of a sudden, I get this squeeling, from my brakes. Not even on them. Could just be cruising down a street or something, and it starts happening.
To get rid of it, i either have to pull up on the e-brake, and let it down, hoping it goes away, or step on the brakes. even doing that doesn't help.
I've looked over everything, up on a lift, and didn't see anything out of the ordinary.
What could it be?
Old Aug 5, 2009 | 05:16 PM
GeauxLadyZ's Avatar
GeauxLadyZ
you POSITIVE its from the brakes?
...100% ?
Old Aug 5, 2009 | 05:32 PM
dmroberson's Avatar
dmroberson
yes... goes away when i step on the brake pedal, or pull on the ebrake... comes back when i let off thought... Occasionally it wont. but it's definitely from the brakes.
Old Aug 5, 2009 | 06:12 PM
dmroberson's Avatar
dmroberson
Oh, if it helps... the only thing I've done to my brakes was change the pads... Installed Project Mu B-Force pads. Thought it might have been due to keeping the OEM shims on, and maybe the pads were still contacting the rotors. took the shims off, reinstalled the pads, and it didn't make any difference.
Old Aug 5, 2009 | 06:41 PM
Badger Z's Avatar
Badger Z
Wheel bearing?
Old Aug 5, 2009 | 07:00 PM
AznKaos15's Avatar
AznKaos15
did you put anti-squeal on the shims?
sounds stupid but same thing happened to me when i changed the pads on my last car.
at the time, i didn't think the anit-squeal stuff would make any difference. was i wrong.
Old Aug 5, 2009 | 07:08 PM
Brake squeal when the brakes are OFF? Don't know how that happens. The pads do NOT touch the rotors. What is there to make noise?
Old Aug 5, 2009 | 07:14 PM
guitman32's Avatar
guitman32
It's normal. Your Project Mu pads will squeal at certain temperatures at certain brake pressures. Don't ask how I know (I run project Mu B-force pads, and have mild squealing, but mainly during the colder FL months).
Obviously, if you didn't use any anti-squeal you're asking for trouble.
Did you bed your pads properly? I suggest doing a re-bed either way, per the instructions on the Stoptech site:
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old Aug 5, 2009 | 07:20 PM
AznKaos15's Avatar
AznKaos15
Originally Posted by davidv
Brake squeal when the brakes are OFF? ... The pads do NOT touch the rotors.
oh really...
Old Aug 5, 2009 | 07:36 PM
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
You haven't heard brake squeal until you run race pads in the cold...lol
Never heard wheel bearings squeal before more like a roar and more noticeable while turning.
Something caught in the brake shield?
Old Aug 5, 2009 | 11:46 PM
dmroberson's Avatar
dmroberson
Yes, I used the antisqueal on the shims... when i took the shims off, I reapplied it to the backside of the pad, only where there wasn't any, from the shims being there. Not sure why it'd be the wheel bearing... when I step on the brake, or pull up on the ebrake, it goes away.
Not sure if I bedded them in or not... Installed the pads a while back...
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
