Gave up
Old Aug 10, 2009 | 08:55 AM
350zinallday's Avatar
350zinallday
Default Gave up
thanks
Old Aug 10, 2009 | 09:08 AM
freedonutss's Avatar
freedonutss
this topic has been discussed many times. please use the SEARCH function.
close thread
Old Aug 10, 2009 | 09:30 AM
cheshirecat79's Avatar
cheshirecat79
If you don't want to deal with camber issues, don't drop the car.
It's that simple.
Old Aug 10, 2009 | 09:31 AM
Don’t give up.
We are here for you. We support you. A shoulder to lean on in your time of need.
Old Aug 10, 2009 | 10:11 AM
Brrcats's Avatar
Brrcats
Originally Posted by 350zinallday
Trying to find out about whether or not which springs to use and am trying not to give up...but I figure I will post and see what happens....any comment is better than nothing
dear god make a understandable sentence
Old Aug 10, 2009 | 10:16 AM
Waiz's Avatar
Waiz
Originally Posted by davidv
Don’t give up.
LOL
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/zU97n-HuAJA&color1=0xb1b1b1&color2=0xcfcfcf&hl=en&feature=player_e mbedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/zU97n-HuAJA&color1=0xb1b1b1&color2=0xcfcfcf&hl=en&feature=player_e mbedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></embed></object>
Old Aug 10, 2009 | 05:54 PM
TheFarmer's Avatar
TheFarmer
2. Eibach Pro Kit (possible rear camber)
If I do the Eibach Pro Kit, does anyone believe I would need the rear camber kit?
You answered your own question
Old Aug 11, 2009 | 07:13 AM
Gsedan35's Avatar
Gsedan35
I was looking at doing either
1. Tein S-Tech (no camber, saves $$)
Only you can look at the after drop alighment specs and say if you need correction or not. The factory has a certain range they recommend you stay within, some guys are totally ok with being out of spec, some aren't.
Discussion now moves to where we are talking about car's that have actually visted the alignment rack,....remember that point. And every car is different, tire and wheel choice does inpact the resluts, remember that point to. Most people are able to install the S-tech setup and be within spec front and rear, we recently had a post from a owner that was not within spec, that was a rare event however. Pro-kits and other 1" or greater drops tend more often then not to not be in spec front and rear. Sometimes the front spec is so close to being in spec that a guy just cannot justify the cost for front correction.
So, if you playing the odd's, and your ok with the milder drop, get the S-tech spring, IMO it's a good spring.
Sad thing is, this same question is going to pop up again in like 2 weeks, Is it really so difficult to do a advanced search or to start on the first page of this section and move backwards to past pages?
lolwatbro
Oct 9, 2021 04:58 AM
Juztin
Nov 22, 2015 07:03 AM
FromGtoZ
Sep 20, 2015 03:41 PM
Calinismo350z
Sep 14, 2015 04:04 PM
unho
Oct 8, 2002 05:33 AM
