tokico hp shocks with hotckis springs
Old Sep 7, 2009 | 01:00 PM
low's Avatar
low
Default tokico hp shocks with hotckis springs
does anyone done this set up or this the set up even good. a noob doing research before buying some suspensions
Old Sep 7, 2009 | 01:06 PM
cdoxp800's Avatar
cdoxp800
I have the Hotchkis Stage 1 TVS Kit with OEM shocks. Rides good to me. May upgrade the shocks someday
Old Sep 7, 2009 | 01:15 PM
low's Avatar
low
thanks. what type of shocks are you thinking of getting?? can you tell a difference with the drop
Old Sep 7, 2009 | 01:24 PM
cdoxp800's Avatar
cdoxp800
As for shocks not sure yet. As for the change with the Hotchkis Stage 1 TVS Kit. Huge difference. To me the car is more responsive and way less body roll. The ride quality is better for sure to me. I am sure a good set of shock would even make it better. I am holding off on shocks right now till I learn more about the types. I have been looking at the adjustable ones. Now those tokico hp don't look bad at all. Seems to me with this setup it would be good for the occasional Auto-cross
Old Sep 7, 2009 | 01:26 PM
Mazinger Z's Avatar
Mazinger Z
I have the TVS1 kit with Tokico D-Specs. It's a firmer but more responsive ride.
Old Sep 7, 2009 | 01:50 PM
low's Avatar
low
i see. well im trying to see what will give me a comfort in ride and also have performance to it. im thinking of getting the hotchkis stage 1 kit. what settings do you have for the sway bar. since i know that it will really affect the way the car handles with the springs
Old Sep 7, 2009 | 01:54 PM
tumzilla's Avatar
tumzilla
you could have bought some tokico d-specs for 499 shipped.
Old Sep 7, 2009 | 02:04 PM
cdoxp800's Avatar
cdoxp800
I think mine are setup like this:
Front = Medium
Rear = Stiff
Old Sep 7, 2009 | 02:35 PM
low's Avatar
low
shoots!! i think on getting the hotchkis stage one and maybe get the tokico shocks. thanks everyone
Old Sep 7, 2009 | 02:38 PM
cdoxp800's Avatar
cdoxp800
No porb. I am sure you will like it once all installed.
Old Sep 23, 2009 | 03:06 PM
Zenpato's Avatar
Zenpato
I've been running the hps with hotchkis springs for about 8k with no issues , noticeably stiffer but car feels planted at high speeds. shocks appear a bit shorter and wider that stocks. I'd recommned for an econ set up.
Old Mar 12, 2010 | 09:54 PM
ZonV's's Avatar
ZonV's
I have the Hotchkis TVS installed on my '05. Very minor drop. A bit stiffer in the front and almost no difference in the rear. We have different stock rear springs. Yours should make even less of a difference. As far as the sways, You won't believe how easy it is to adjust. So play with them until you get the feel you want, screw anyone's recommendations. Basically, the stiffer the front compared to your rears, the more understeer, etc. Stiffer sways are better for high speed stability, but a little roll is good on the streets.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Suffolk350z
Sep 13, 2015 02:43 PM
