Question regarding Coilover installation - Not in DIY
Old Sep 23, 2009 | 09:31 AM
solidfish's Avatar
solidfish
Default Question regarding Coilover installation - Not in DIY
I checked our DIY section for a coilover installation guide, but could not find one. I think the install process is pretty straight forward so I should be alright. But I did have one question:
Do we need to use spring compressors when removing the front or rear springs? I think the front comes out completely with the shock assembly so no compressor should be needed. What about the back?
Thanks!
Old Sep 23, 2009 | 09:34 AM
TheFarmer's Avatar
TheFarmer
If you're doing coilovers, you shouldn't need a spring compressor Front shock/spring combo is completely replaced and the rear springs can be removed w/o a compressor since they just come out after lowering one side of each lower a-arm.
Old Sep 23, 2009 | 10:15 AM
VR3's Avatar
VR3
^+1
I would also get one just in case from Autozone since they offer free rentals.
Old Sep 23, 2009 | 10:37 AM
scotts300's Avatar
scotts300
No spring compressor needed for C/O install.
Old Sep 23, 2009 | 10:41 AM
bad 350z's Avatar
bad 350z
just put a jack under ur rear lower controll arm and let it dwn after all ur bolts are out u dnt need spring compressers..
Old Sep 23, 2009 | 11:00 AM
solidfish's Avatar
solidfish
awesome! Thanks for the replies!
Old Sep 23, 2009 | 11:04 AM
Voboy's Avatar
Voboy
Yes spring compressors are needed for the front if the coilover they are going to install reuses the rubber mounts...ex: kw variants, bilstein pss's
Old Sep 23, 2009 | 11:30 AM
scotts300's Avatar
scotts300
So which COs did you decide on? Hopefully you'll have it ready in time for the next autox! We had one 350z in each session while I was there. We could have used more though!
Old Sep 23, 2009 | 12:23 PM
phunkenstein's Avatar
phunkenstein
That's exactly what I did on my G. Same ****. You don't need a compressor.
Old Sep 23, 2009 | 12:40 PM
solidfish's Avatar
solidfish
hey scott,
Well I was looking for some entry level coilovers, possibly the BC Racing or Stance LX, but by chance, ran across some very cheap H&R. From the few reviews, they seem to be alright so I decided to give them a try. I've used H&R on my previous Audi, so I'm already a fan of the brand. We'll see how they work out.
Did you do well at last week's session? I'll definitely try to make it next month.
Last month I did a bit better than my marina run. (Never went off course ) I kept a consistent decrease in time. Shredded the heck out of my street tires though. I actually have divots in the tire. I think my driving style is a bit harsh. I'm getting a lot of wheel spin and tire screech. Doesnt feel as finesse, as the other veteran drivers...
I'll practice to have a bit more flow through the course, possibly even reduce tire wear while keeping runtimes low.
john
Old Sep 23, 2009 | 02:33 PM
scotts300's Avatar
scotts300
Originally Posted by solidfish
hey scott,
john
Hey John!
Do you not get the results distribution? They were sent yesterday. I didn't do as well overall as I have been doing since I borrowed a friend's Z that doesn't have any suspension mods. I did manage to win in the B class though, so that was good. There is a good battle going on in your class, E, for first place. Z vs S2k!
I'd be happy to ride with you next month if you make it out to see if there is something in your driving causing the chatter you described. Maybe it's something simple like tire pressure, or maybe your street tires are just pooh!
NFAC
Sep 26, 2015 10:11 PM
