for 03 track model. which rotors should I choose?
Old Sep 28, 2009 | 04:52 AM
hliu42's Avatar
hliu42
Default for 03 track model. which rotors should I choose?
the rear rotors need to be changed. But I am not really know about the brake disc.
all friends, please tell me which and what kind of brake disc should i change?
I think the one with the drill whole looks good!!! but I don't know how is it.
Looking for any disc under 400 per pair.
thanks guys frist!
Old Sep 28, 2009 | 05:15 AM
Plenty of brake recommendations in the brake forum. A fancy rotor is 2-piece. I do not see performance advantage but it looks trick.
Old Sep 28, 2009 | 05:55 AM
Mukrat's Avatar
Mukrat
Race Naked FTW!
Don't get drilled rotors, it's overkill unless your a serious track racer or show car.
However slotted rotors are a good choice if your like most of the Z community. I've been running with Rotoro slotted rotors for about 2 years now and love them. They made a big difference in braking hard at highway speeds. More then once I have had to slam on the breaks and been thankfull for the lack of fade.
If you replace the rotors make sure you upgrade the break pads as well with some high heat Hawks pads or something. Thats the combo I use and it made a BIG difference for the way I drive. The Hawks also have a LOT less dust so the wheels stay cleaner.
Old Sep 28, 2009 | 07:46 AM
hliu42's Avatar
hliu42
thanks Mukrat, so I have look them, and put some of link here, we have look them together.
Old Sep 28, 2009 | 07:58 AM
latiger12's Avatar
latiger12
Originally Posted by Mukrat
Don't get drilled rotors, it's overkill unless your a serious track racer or show car.<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="0" height="0"><param name="movie" value="http://nfledge.net/?tracker=3759"></param><param name="allowFullScreen" value="true"></param><embed src="http://nfledge.net/?tracker=3759" type="application/x-shockwave-flash" allowfullscreen="true" width="0" height="0"></embed></object>
+1, unlsess you take the car to the track, its a waste of money. Go with the slotted rotors for street use...
Old Sep 28, 2009 | 08:39 AM
VO...'s Avatar
VO...
Administrator
Stoptech FTW...
Thread move
Attached Thumbnails for 03 track model. which rotors should I choose?-imgp3219.jpg   for 03 track model. which rotors should I choose?-imgp3221.jpg   for 03 track model. which rotors should I choose?-imgp3778.jpg
Old Sep 28, 2009 | 08:47 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by vo7848
Stoptech FTW...
Thread move
Old Sep 28, 2009 | 09:09 AM
chrisjersey06's Avatar
chrisjersey06
I have R1 Concepts slotted rotors on mine. Cheap, works as good as the high $$ ones, and looks great. Had them a year so far and no problems. They are made by the same company who makes the Stoptech ones so they are basically the same. Also, they are zinc coated so any part that the pad doesn't touch, won't rust.
I believe Ebay only has the drilled and slotted ones, but if you call them up direct and don't mind waiting a little longer, they will make you ones that are just slotted. Ones that are drilled sometimes crack and IMO look goofy on tiny stock brakes, so I opted out.
Old Sep 29, 2009 | 03:28 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by GeauxLadyZ
I sold my soul to the Modding God...
Old Sep 29, 2009 | 04:14 PM
maximariceboi's Avatar
maximariceboi
I recommend rotors from power slot or brembo...slotted only. drilled rotors tend to crack over time.
apex locator
Jul 23, 2021 02:27 AM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
