Requesting Pics - Coilovers Installation
Old Sep 30, 2009 | 07:03 PM
solidfish's Avatar
solidfish
Default Requesting Pics - Coilovers Installation
I'm in the process of installing my coilovers right now. I needed some quick reference pics of the rear OEM coilovers sitting inside the OEM location. I'm not seeing how the spring mount is supposed to be positioned. Do we remove the upper spring mount??
Searching for pics and all I'm finding are spring installs...
Thanks!
Old Sep 30, 2009 | 10:49 PM
pfregeolle's Avatar
pfregeolle
Uploading pix now to photobucket. My kit came with new uppermounts for the springs in the rear. Ill post pix in a minute. hope it helps.
Old Sep 30, 2009 | 10:59 PM
pfregeolle's Avatar
pfregeolle
Here ya go!
Old Oct 1, 2009 | 08:33 AM
solidfish's Avatar
solidfish
Originally Posted by pfregeolle
Here ya go!
Ah thats perfect, thanks! Unfortunately, mine did not come with those mounts so I had to fabricate one using the the OEM spring mount. I think it'll work well but wondering if there are others out there would had to custom make a spring mount for the rear coilovers??
Old Oct 1, 2009 | 10:05 AM
350ZPK's Avatar
350ZPK
Here ya go!
Old Oct 1, 2009 | 11:16 AM
pfregeolle's Avatar
pfregeolle
Old Oct 1, 2009 | 11:28 AM
terrasmak's Avatar
What coilovers , different coilovers use different hardware
Old Oct 1, 2009 | 11:37 AM
solidfish's Avatar
solidfish
H&R coilovers. I see that Stance/BC uses OEM, and as shown above, Greddy provides their own. But H&R doesn't provide anything. The top adjustment perch is solid so the OEM spring mount cannot be used.
So what I've done is cut the spring mount (as if doing the spring mount mod) and used the cut piece. Problem is, nothing is really holding this in place other than the pressure of the springs. I'm looking for something like this greddy kit where the mount has a small lip to hold the coilovers in place.
Are there any other coilovers out there that do not reuse the OEM spring mount?
Old Oct 1, 2009 | 03:13 PM
terrasmak's Avatar
My BC's are like that , none of the OEM hardware is used. Alum plate with my adjuster on top , alum plate to adapt to the 2.5 or 2.75 id springs on bottom.
Old Oct 1, 2009 | 03:16 PM
solidfish's Avatar
solidfish
So did you use anything inbetween the aluminum plate and vehicle? or is it sitting metal against metal? I'm assuming some type of rubber padding is needed or else it'll get noisy, possibly rust too??
Old Oct 1, 2009 | 03:17 PM
solidfish's Avatar
solidfish
ps.
I'll post pics of my install later tonight. Probably be a good reference for future users...
Old Oct 1, 2009 | 05:04 PM
terrasmak's Avatar
Just straight against it , top and bottom if i remember right.
Old Oct 2, 2009 | 06:46 PM
pfregeolle's Avatar
pfregeolle
You can reuse the bottom mount for the spring....you shouldn't have to have the bottom of the spring sitting metal against metal.
