Parts information needed for front suspension...
Old Nov 29, 2009 | 09:00 AM
Dr.TuB's Avatar
Dr.TuB
Default Parts information needed for front suspension...
I have a problem with my suspension/axel
the front passenger's control arm that is connected to the wheel assembly has worn rubber that has chuncks of oil/dirt. i was told by my mechanic that it needs to be replaced.
does anyone know what the part that is connected to the control arm is called and where i can purchase this from?
Old Nov 29, 2009 | 09:05 AM
zerafian's Avatar
zerafian
Are there any Nissan dealerships near you? I ahve to ask since your in Europe. Go to http://www.courtesyparts.com/350z-pa...008-c-714.html they have parts, part numbers, and pictures that show what you probably need. Youll just need to search for it.
edit: in that link go under genuin nissan parts
Old Nov 29, 2009 | 09:27 AM
Dr.TuB's Avatar
Dr.TuB
im trying to stay away from the dealership. they are quoting me 1300USD just for parts.... japanese car parts are actually more expensive than european car parts for some reason
Old Nov 29, 2009 | 10:43 AM
Dr.TuB's Avatar
Dr.TuB
Default Problem with suspension... pics inside
here is are some pictures of the problem
what are the parts that i need to purchase and replace?
and where can i buy them.
Old Nov 29, 2009 | 11:27 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the ball joints are not sold separately IIRC
Old Nov 29, 2009 | 12:06 PM
DavesZ#3's Avatar
DavesZ#3
Merged
Dr.TuB - Please don't start new threads for the same problem. Keep all your posts together as it makes it easier for everybody to follow what is happening.
Old Nov 29, 2009 | 12:33 PM
gregom's Avatar
gregom
That ball joint isn't part of the lower control arm, its part of the steering knuckle/spindle. It's the entire center piece where everything connects to it, the wheel hub, all the control arms and steering. I don't see it for sale on Z1's website.
I had to replace mine after a collision, it's a $300 part. I bought it at autocenter.net
http://www.trademotion.com/partlocat...layCatalogid=0
I replaced it myself... and i'm not a mechanic, but if you are good at tearing things apart and putting them back together this will be something you can do.
Now Nissan doesn't sell new ball joints, but its possible your ball joint is not damaged and all you need is a new boot. You may be able to find a general size boot and just remove your current one and install a new one with new silicone grease or whatever is inside. Although if you've not done something like this before i'd have a mechanic who does suspension stuff do it. However if your ball joint is damaged replacing the boot wont help much, it will still bind up and cause all kinds of noise going over bumps. Eventually it will fail and break, disconnecting your lower control arm from the spindle then you'll be in big trouble.
Old Nov 29, 2009 | 12:50 PM
Z1 Performance
Former Sponsor
ah you're right, my bad
we don't have these on our site yet...it's one of those things that's on the list to do lol, but it is a fairy straightforward thing to replace. You'll need an alignment afterwards
m_0g
Jun 3, 2021 10:05 AM
codek
Sep 27, 2015 03:21 PM
Brantwilliams13
Sep 16, 2015 05:03 AM
ILoveDrifting
Sep 7, 2015 03:15 PM
