1 inch drop front and back question
Old Jan 24, 2010 | 06:57 PM
chrisj485's Avatar
chrisj485
Default 1 inch drop front and back question
I plan on getting the Eibach Pro lowering springs for my '07 Z (1 inch drop front/rear). I've been reading countless threads on whether or not I will need a camber kit for the rear. Some say if you go OVER 1 inch than, yes...others say, 1 inch is pushing it...can someone chime in and perhaps give me an experienced answer? Thank you very much.
Old Jan 24, 2010 | 07:35 PM
QuicksilverZ33's Avatar
QuicksilverZ33
There is no answer. Every car is diff. Put the springs in, then get an aligment. That will give you the answer to whether you need the camber kit or not. I would buy it anyway.
Old Jan 24, 2010 | 07:37 PM
jbaker1121's Avatar
jbaker1121
you won't need it unless you get wider wheels
Old Jan 24, 2010 | 08:12 PM
terrasmak's Avatar
Please don't try to help
OP, most likely you will need a rear kit, the front will be about -1.5 with that drop , but the rear will be a lot more and the toe won't be able to be brought into spec. Just pay the $160 for the rear kit.
Old Jan 24, 2010 | 08:19 PM
0jiggy0's Avatar
0jiggy0
Old Jan 24, 2010 | 09:38 PM
Anomaly's Avatar
Anomaly
My answer on the rear camber kit with the Eibach Pro-Kit from the Lowering Springs Picture Thread:
Originally Posted by Anomaly
Rear camber kit is a 'maybe' answer but I went ahead and purchased the kit with my springs and had everything installed at the same time. If I hadn't I'm pretty certain that the rear kit would have been required to be added anyways so playing it safe paid off.
The benefit to getting the camber kit from the start is that you won't have to deal with finding out after an alignment that you should have ordered/installed the camber kit; which means no waiting for the kit to arrive, schedule the install, and have the alignment done again.
Old Jan 25, 2010 | 01:35 AM
chrisj485's Avatar
chrisj485
Awesome...I appreciate the info everyone..I'll go ahead and get the camber kit for the rear so it will get done right the first time...thanks again
Old Jan 26, 2010 | 02:57 PM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
+1. I did the Prokit on my G and had no need for an alignment kit. Others with the same kit needed at times and not with others. Every car is built a tad different.
Old Jan 26, 2010 | 03:03 PM
jduet's Avatar
jduet
Old Jan 28, 2010 | 05:38 AM
chrisj485's Avatar
chrisj485
1 other question I had, is, will I need just a rear camber kit or a camber and toe kit for the rear?
Old Jan 28, 2010 | 05:44 AM
JasonZ-YA's Avatar
JasonZ-YA
yes the camber and toe kit.......
you need a pair of rear adjustable camber arms - any brand you pick
and the spc toe bolt #72055
you can see my links here: https://my350z.com/forum/8093425-post2.html
-J
Old Jul 5, 2011 | 08:56 PM
peter manothay's Avatar
peter manothay
lol yo these smiley faces are hilarious!
Old Jul 5, 2011 | 09:02 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
uhhh WHAT?
RiujinZero
Apr 16, 2021 11:31 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Ace2347
Sep 22, 2015 03:12 AM
