help with rear brembos asap
Old Feb 26, 2010 | 11:10 AM
stewieisslow's Avatar
stewieisslow
Default help with rear brembos asap
went to get my break pads changed for my rear brembos and they say i need pads and rotors....is there anything cheaper than oem out there???? they told me 725 for everything oem installed
Old Feb 26, 2010 | 11:24 AM
DavesZ#3's Avatar
DavesZ#3
Of course there is cheaper. Check almost any of the vendors here...
https://my350z.com/forum/vendor_directory.php
Old Feb 26, 2010 | 12:27 PM
03brembo's Avatar
03brembo
maybe see if you could get your rotors turned, napa does em for $12 bucks each. I got rear pads off craigslist for free and you could install em yourself.
Old Feb 26, 2010 | 12:33 PM
stewieisslow
anyone know the cheapest vendor i could use? and ya ill check out napa
Old Feb 26, 2010 | 12:36 PM
stewieisslow
and on the vendor sites i cant really tell which rotors and pads i could use for the brembo brakes
Old Feb 26, 2010 | 01:01 PM
Parker01's Avatar
Parker01
This is as cheap as they come:
https://my350z.com/forum/brakes/4424...9-shipped.html
Install them yourself if you are the slightest bit mechanically inclined, Brembo's are dead simple to install new pads/rotors.
Old Feb 26, 2010 | 01:09 PM
I began a R1 Concepts thread some time ago. Very informative.
Old Feb 26, 2010 | 01:26 PM
NismoZ_840's Avatar
NismoZ_840
How old is the car/rotors, years/miles? Seems like stealerships often want to put on new rotors at every brake change. A bit pricey for OEM Brembo rotors at several hundred apiece! They should be replaced when too thin (70k-100k Daily driver miles sound about right? Actual Minimum Width Specs?), cracked, or warped beyond turning. Should be about $50 for corner auto parts store for complete set of rear brakes, and $50 or so per no-name rotors.
Old Feb 26, 2010 | 02:26 PM
terrasmak's Avatar
First you my want to look into BRAKES, not breaks. Second like mentioned, dealer and others want to replace the rotors and make as much off you as possible. Chances are you can just get pads, and NO rotors do not need to be turned every time the pads are swapped.
