How corrosive is brake fluid?
Ok, I'll admit I was lazy this year, so I took my Z in to have the radiator flushed as well as oil, trans, and diff fluids changed. I usually do this myself cuz i love working on my car but weather is getting nice and work schedule is hectic still.
Anyways while i had it in i wanted to get the brakes inspected. Was told the rotors looked "OK" but the pads were shot. I'm thinking that's fine I'll get some decent pads to last the season cuz this winter I want a big brake kit anyways.
So today I was in a hurry to get the pads changed cuz it was f'n gorgeous out and didn't pay attention to the brake fluid level. I just undid the cap and started replacing pads. After I'm all done I notice brake fluid all over the ground under my car. I freaking panic and think I tore a line. NOPE some jack off where i had it serviced topped off the fluid so there was no excess room for the fluid to go when the calipers were compressed to make room for fresh pads. Now I have brake fluid all over a ton of crap under the car. Including some wiring that routes under the master cylinder.
I tried to clean it up the best i could but my damn hands can't get down in there. Is this bad and if so how bad is it? I know this stuff has been said to strip paint. Is there any special cleaners to use?
well, i cant see how its the "jack offs" fault...........If the fluid is even at the LOW marker of the brake master plastic reservoir - then when pushing the caliper pistons back in, it will overflow......so if he put the fluid level within the range this WILL happen......
I wrap around the master with shop towel, not hand rags and then wipe away any fluid residual that may have dripped down, usually its none..
-J
-J
Thanks. I didn't see anything in the detailing section but I'll go back and check. Was kind of freaking out so I'll admit i didn't look that hard.
In any other car I've ever owned or worked on I've never had the master cylinder reservoir overflow. If the brake fluid is below the Minimum line than it usually means some other problem exists and topping it off isn't going to solve it.
I learned my lesson by being lazy I guess. It wasn't just a slight overflow either. There was a lot...I mean a lot of fluid that came out. A small overflow I could have lived with.
Regardless I'll go check the detailing section. Thanks for the advice.
If i do the same thing, (happens from time to time) i dump a gallon or two in the master cylinder hole to rinse it out. No big deal if you do it within an hour or so.
^ ya, you also have to remember, there master cylinder area is its own blocked off engine bay area...........designed to funnel and trap that stuff.....its really not that bad, just clean it up...
-J
-J
Wow...Didn't know the Nissan engineers thought about things like brake fluid spills. Too bad I waited until today to find out I could just dump some water down there and now the stuff has sat for a day.
Oh well, I still flush. Seems counter intuitive to dump water into car though but hey I've probably done worse to a vehicle.
Thanks for all the help. Next time I'll do all the service myself and be prepared to catch some fluid.
