Suspension 101
Old Jul 22, 2015 | 07:00 PM
  #981
NecktieNinja's Avatar
NecktieNinja
Default Will it rub?!?
Just bought a set of Teins Street Basis for my 08 z. I have my stock nismo wheels (f:18x9, r: 19x10) and my tire specs are f:245/35R18 r:265/35R19....
I am planning on lowering maybe an inch? around there, just to get rid of most of the wheel gap. Anyone know if it will rub on either ends? Fronts fenders are rolled by factory, and rears are not rolled yet. Will I need to roll the rears? Camber? If so, how much camber? I am trying to stay away from camber as much as possible. And yes, i am very clueless on this haha. Thanks for the help guys!
Old Jul 24, 2015 | 09:44 PM
  #982
illestcarmedia's Avatar
illestcarmedia
Looking for a straight answer, cant seem to find it. I have an 05 g35 coupe mt... currently stock setup wanted to know if 07 g35s suspention will work on the 05...
Thanx in advance
Old Jul 25, 2015 | 05:00 AM
  #983
driftsucky's Avatar
driftsucky
Will it "work"? Yes. will it bolt up directly? No. Will it lower your car? No. Is it worth doing? No.
Old Jul 25, 2015 | 08:45 AM
  #984
illestcarmedia
Lol thank you hahaha.... guess it time to dig into some suspention research
Old Jul 25, 2015 | 09:58 AM
  #985
illestcarmedia
Really like to thank the guy that started this thread.. Mad props, **** ton of info. I appreciate the time you took to gather and post this extremely valuable info.. after reading the first clp pages of this thread I'm coming to the realization that I don't know if I'm ready for the suspension / lowering game on my Infiniti ... im coming from an 04 rx8 and the Rx8 was so much simpler.. pretty much direct bolt on with a true coilover, and then an alignment.. i got a chance to glance at the suspention on my g35 and noticed how different it was from my 8... now i truely realize how much different ... im not looking to get spoon fed, just want to make sure i understand the requirements to lower a street driven g35. Never tracked before just like my cars to have a nice stance, so i know i dont really need extras , like adjustable caster. Looking for around a nice 1.5 in drop...the black 350/70 i seen o. This thread has a really nice look too it...reading this thread i seen the pss9's are a good direction to go, but im looking for a true coilover set up ... (insert suggestion here).. from what ive read i will need adjustable camber upper control arms in front, rear camber arms, also toe bolts for the rear... just want to make sure im not missing anything .. and in really appreciate the guidance for a new G owner ...
Old Jul 27, 2015 | 03:34 AM
  #986
Row2K's Avatar
Row2K
Pss9 or Pss10 are an excellent street coilover and there really is no need for you to look any further unless you need something specific ie.: heavy track use or slamming/completellyruiningyourhandlingandrideheight.
Additionally unless there is a very specific reason for which you wish to go with a true dual, there simply is no need and it's arguably worse for the geometry of the rear suspension. I recommend you search a bit on this topic if it's something that is very important to you based on some specific need as there are a few very interesting and very technical discussions on the topic of rear geometry and spring bucket vs. knuckle mounted springs.
Old Jul 27, 2015 | 08:16 AM
  #987
illestcarmedia
I acctually Did a little more research.. and i aggree.. im not tracking the car so im going to go with an oem style setup ... probally going to grab a set of BC coils .. my previous post was more geared toward additional hardware i am going to need inorder to lower the car .. (parts needed other than the ones i listed)
Old Jul 28, 2015 | 12:36 AM
  #988
Row2K's Avatar
Row2K
you have good timing: https://my350z.com/forum/suspension/...pss10-kit.html
Here's some of the supporting gear I use after trying a few different options over the years. There is more on my car, but these are the only pieces you need for a drop and proper alignment:
-Cusco front upper A-arms (8 years of trouble free usage...single best part I bought)
-Battle Version rear camber arms (Alex Pfeiffer gave his blessing so good for me)
-SPC rear toe bolts
Old Jul 28, 2015 | 09:59 PM
  #989
illestcarmedia
-SPC rear toe bolts
Oh man .... you are a life saver!!!!! And the bilstein's are better than the bc's from what i read..
Old Aug 17, 2015 | 12:27 AM
  #990
350Z.'s Avatar
350Z.
I have wheels: Front 19x9.5 with offset +12, Rear 19x11 with offset 25+
I also have adjustable Coilover, but I have not install wheels and coilover yet.
As what I read the first page in this thread, I need " Rear Camber" ?
Is there any thing els I need?
Thank you
Old Aug 17, 2015 | 08:55 PM
  #991
terrasmak's Avatar
Thank you
Camber kit will bepend on how low you drop the car
Old Aug 21, 2015 | 09:29 PM
  #992
superlim9's Avatar
superlim9
What are some of you track guys setting your front to rear rake at?
Old Aug 22, 2015 | 03:05 AM
  #993
350Z.'s Avatar
350Z.
I am dropping my car front 1.5 inch and rear 2 inches . Do I really need a camber ? and if so what is the maximum low allowed with no camber ?
Old Aug 26, 2015 | 08:24 AM
  #994
terrasmak's Avatar
Try one more time to express what you are trying to ask
Old Sep 2, 2015 | 04:45 PM
  #995
Mw870's Avatar
Mw870
Default BC racing vs virtue?
Hey all just a quick question, I've heard nothing but good things about BC racing type BR coil-overs, after talking to my brother though he's recommending Virtue coil-overs they both come to near the same price, except being my brothers car is sponsored by virtue motorsports I could get a discount there, I've just not been able to find much if anything on Virtue coil-overs for our cars...hoping someone is able to shed some light on these or if I should just stick with BC racing.
Old Sep 6, 2015 | 05:10 PM
  #996
dragon11689's Avatar
dragon11689
So this happened. It's on the inner part of inner tie rod. I'm assuming this is a steering rack leak. Anyone know if this can be repaired or do I need a whole new steering rack? Thanks in advance.
Old Sep 6, 2015 | 09:02 PM
  #997
terrasmak's Avatar
It's the rack, I have yet to see a seal kit. If one is available , I need one for mine
Old Sep 7, 2015 | 11:03 AM
  #998
dragon11689
Damn...it looks like 2nd replacement now...I'm making this car a weekend/track car. Too expensive to be a daily at this point. I have track prepped suspension. So that's where it needs to stay.
I've been having issues with car swaying left to right as I'm changing lanes or making turns. I'm wondering if this is the culprit. I've checked suspension front to back and everything else looks tight.
Old Sep 7, 2015 | 02:46 PM
  #999
terrasmak's Avatar
Doubt it is the problem, mine has been leaking for 5 years now. The weird sway is most likely rear toe.
Old Sep 7, 2015 | 07:20 PM
  #1000
dragon11689
Hmmm...wonder if it could be the bushing for rear midlink...although I've been told that rear bushings aren't usually known to go bad unless it's really high mileage. I hit about 120k on it so far.
