Eibach Rear springs showing no drop.
Old Apr 16, 2010 | 12:37 PM
A4T350Z's Avatar
A4T350Z
Default Eibach Rear springs showing no drop.
So I found a little bit of time and installed my rear eibach spring. I said spring because I installed one and then noticed the car did not sit any lower. I followed the DIY install and did everything as described. Also, this is not the first car I did an install on, but it is the first 350z.
The rear driver side is installed on a 265-35-18 and it is sitting on flat ground (garage floor). It measures 27 1/4 inches from the ground to the lip of the rear fender. The pass side which is still factory on a 245-45-18 is reading an even 27 inches off the ground to the same point.
Question- Do rear Eibach springs install upside down in the way that the letters are upside down which are written on the spring coils??? Or do they install where you can read the part number and Eibach logo normally when looking at it? Also, I did not trim the strut ruber on top that everyone seems to mod to get the car even lower. My Eibachs are 6364.002 in the rear.
Old Apr 16, 2010 | 01:01 PM
tribal_visionz's Avatar
tribal_visionz
If you only installer one rear spring, the other side is not giving you accurate results. And yeah maybe you installed them backwards, but I'm not sure which way they go.
Old Apr 16, 2010 | 01:03 PM
A4T350Z's Avatar
A4T350Z
For some reason I think I read somewhere a long time ago that the 350z rear eibach spring needs to be installed to where the letters are upside down... I def. installed the rear spring in the rear placement.
Old Apr 16, 2010 | 01:12 PM
350z00m's Avatar
350z00m
mine did the same thing.... but once u intsall both and let them settle in a bit... it will drop... mine has no gap in the rear or the front.... with the pro-kit
Old Apr 16, 2010 | 01:22 PM
diablox1's Avatar
diablox1
fail for judging results with 1) not letting the springs settle, 2) only one spring installed 3) doing both (1) and (2) after having claimed to have done a few other spring installs.
cmon man, you should realize that dude. I installed the same eibach springs and have the exact results I was expecting from them.
the instructions should tell you which way the springs should be installed. they can be downloaded from eibach's website if you don't have a hardcopy.
Old Apr 16, 2010 | 01:35 PM
A4T350Z's Avatar
A4T350Z
Ohh I figured they need time to settle. I also thought they would show a little bit of a drop over factory, not a increase in height. And since its independent rear susp. i didnt think the other side not being installed would effect it.
Old Apr 16, 2010 | 01:46 PM
duro78's Avatar
duro78
This doesnt make any sense you installed 1 spring didnt notice a drop then left it alone, then wrote a thread about it. How could you possibly notice a drop if the other springs are at stock height
03brembo's Avatar
03brembo
give em a little time to settle if you think you did it right or spring mount mod that b
Old Apr 16, 2010 | 02:44 PM
Not sure how you can install linear springs upside-down. If the bottom seat fits properly, it should be good to go. How about a photo for members to see and comment.
Old Apr 16, 2010 | 04:15 PM
A4T350Z's Avatar
A4T350Z
I did not leave it alone just for the sake of not doing it after. I had to go to work and did not have time to do the other side or the front until tomorrow. I am actually at work as we speak.
Old Apr 16, 2010 | 04:39 PM
IronAss's Avatar
IronAss
Pretty sure with progressive springs (eibachs are progressive) you install with the coils that r closer together towards the top. I think that should make the writing normal and upright also.
Old Apr 16, 2010 | 04:56 PM
carlili4190's Avatar
carlili4190
I think this is the main thing especially when it comes to just springs...
