hotchkis shaft collar?
Old Apr 17, 2010 | 10:47 AM
tw8715's Avatar
tw8715
Default hotchkis shaft collar?
so i heard there is a fix for the sway bar shifting on hard turns.
can anyone help? or help me find a post?
thanks!
Old Apr 17, 2010 | 09:18 PM
terrasmak's Avatar
Is yours an older bar with no collars?
Old Apr 17, 2010 | 10:44 PM
tw8715's Avatar
tw8715
no has the collars but still some play. can hear the bar shift on hard turns.
Old Apr 18, 2010 | 09:28 AM
halfrice's Avatar
halfrice
might want to try to tighten them back up, my nuts came loose after a few track days and it started to make noise on hard turns, just tightened them back up and cars quiet again.
Old Apr 18, 2010 | 09:56 AM
DavesZ#3's Avatar
DavesZ#3
If I remember correctly, there is a little slop in the two mounting brackets, you need to force them outward against the collars as you tighten down on the bolts to they keep a tight fit against the collars.
Old Apr 18, 2010 | 10:53 AM
tw8715's Avatar
tw8715
I got to get under there again i guess. I bought them used and had to reuse the front oem brackets. Might be the cause??
Old Apr 18, 2010 | 11:14 AM
terrasmak's Avatar
You can hear the bar shift ? Doubt it, and no it doesn't affect performance, well maybe at an F1 level, but not at the level any of us can feel or drive at.
Old Apr 18, 2010 | 11:38 AM
DavesZ#3's Avatar
DavesZ#3
It doesn't come with front brackets, you have to reuse the OEM brackets.
Old Apr 18, 2010 | 12:16 PM
tw8715's Avatar
tw8715
Oh ic. So there is some play on the brackets and you can push them inward towards the collar? Seems like they are right in place. Will give it a try
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
Depravity
Oct 1, 2015 04:49 PM
RiujinZero
Sep 25, 2015 01:19 PM
