previous owner ripped abs plugs off!!!
Old Apr 29, 2010 | 05:54 PM
Jlynch24's Avatar
Jlynch24
Default previous owner ripped abs plugs off!!!
ok so i just got my z back together (03 performance) but since the previous owner was going to make a track car out of it the front abs plugs are ripped out and m.i.a. the wires on both ends are still there but i need to know from you tech guys what color go to what colors on the front only the rears were untouched. i just got the ''g'' sensor put back in behind the shifter but all lights were still on vdc, trac, abs, cruise doesnt work! any help would be appreciated. and i did search but i guess not many people have had this problem
Old Apr 29, 2010 | 08:57 PM
terrasmak's Avatar
I'll look tomorrow when i pull my front wheels off for more suspension adjustment
Old Apr 30, 2010 | 08:00 AM
Chebosto's Avatar
Chebosto
is the cable to the ABS box still plugged in?
its the silver aluminum block with several thin metal tubes going to it that is located in the engine bay under the BRAKE cover, near the master cylinder and resevoir.
should be a grey connector that plugs into the ABS controller...
Old Apr 30, 2010 | 12:18 PM
JasonZ-YA's Avatar
JasonZ-YA
Poor Track car, free from abs then......boo.....................
-J
Old May 2, 2010 | 04:22 AM
Jlynch24's Avatar
Jlynch24
yes, all is plugged up at the abs controller under the hood
Old May 2, 2010 | 11:05 AM
terrasmak's Avatar
I'll post in a few, i have more ride height crap to play with shortly. Forgot yesterday
Old May 2, 2010 | 05:32 PM
Jlynch24's Avatar
Jlynch24
ok so update time, after talking to a nissan tech he told me that the abs wires do not matter which one they go to because of ac like current they use, so i de-pinned the connectors and wired them up and it worked great, all the lights are now off on the dash and the vdc button now works. Still cruise is not working though, the light comes on but it cant be set. thanks for all the input
liqalu04
Jan 2, 2022 12:58 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
