Camber Arm Construction... Can these even be used?
Old May 1, 2010 | 11:43 PM
Tiltz's Avatar
Tiltz
Default Camber Arm Construction... Can these even be used?
I recently purchased these off of another board member. They were advertised as Stillen Camber Arms, however I don't think they are, because they seem to be so crappily constructed. The rod ends were pretty much toast, but I am pretty sure I can get some replacements at a 4x4 shop. I more worried about the tolerances of the arms and the differences between both arms.
Notice the bends are slightly different
Left arm sits slightly flat while the other doesn't
The arms don't look like they were tweaked because of an accident or anything. They were dirty and well used and after I cleaned them up I found all of the parts to be heavy duty. Their wasn't any rust, just grime.... But yeah both arms are slightly different. Is this gonna be a problem, or should it not matter since they are adjustable and the lengths can be matched up.
Old May 2, 2010 | 05:01 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'd toss those in the trash
Old May 2, 2010 | 05:10 AM
JasonZ-YA's Avatar
JasonZ-YA
I myself would as well but its your car and your choice......
those are some ebay stillen look alikes......
OEM CAMBER ARM - FYI:
The factory non adjustable camber arm is a hollow weak properties steel with a bend in it "by design" its designed by Nissan to be the weak point in case of a curb check/accident, etc........
if anyone ever taps a curb, etc the camber arm is the first thing to bend......and from nissan is a about a 24 dollar replacement.....
Stillen and a few others mimic this 'kink' in their aftermarket designs, but whatever..........don't be hitting curbs..... which is what i think happened to this arm.
That arm like i said looks to be an ebay special - which is made with cheap schedule 40 or weaker ductile steel.......the rod ends are of cheap casting with steel spacers on each end that fit inside it.......usually 5/8-18 rod ends.....
up to you.......
-J
Old May 2, 2010 | 06:24 AM
Guilty1s's Avatar
Guilty1s
Im sorry but the was completely noticable in the FS thread... i saw it but didnt feel like taking a **** on someones thread for something so noticable... i think it may have even been mentioned too.
Old May 2, 2010 | 09:22 AM
Tiltz's Avatar
Tiltz
I didn't notice it and the seller didn't mention it. I just thought dirty stillen arms that need new rod ends for a good deal.
But... I am not gonna use them, I'll just send them back.
I bought brand new toe spc toe bolts. People say camber doesn't kill tires. Am I gonna be good if I just install the toebolts?
Old May 2, 2010 | 10:31 AM
Gibbs's Avatar
Gibbs
Know it all
Camber kills tires!!
Old May 2, 2010 | 10:42 AM
JasonZ-YA's Avatar
JasonZ-YA
When people say that they are usually and if anything*.....accepting out of spec camber for the FRONT, way out of spec camber on the rear (driving tires) is gonna be an issue....
depending on how low you are, and how much out of spec your camber is in the rear is what will determine if you will "kill" tires.....
up to you, monitor them and decide after you get an alignment with the install of ONLY spc toe bolts...
-J
Old May 2, 2010 | 11:08 AM
Z1NONLY's Avatar
Z1NONLY
Bad toe kills faster.
Old May 2, 2010 | 03:11 PM
Tiltz's Avatar
Tiltz
-J
Word, Ill go for the lifetime alignment at firestone. When/if my T1rs are starting to die Ill dismount them and do a side to side tire rotation and install the camber arms, then realign.
Old May 3, 2010 | 05:38 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
FYI, the bend or kink is necessary for the rear endlinks not to contact the camber arm under heavy suspension roll. Early on when we first designed our camber arms, we tried a straight design but found that in testing on track that there would be marks on the camber arm from where the endlinks contact the arms.
Old May 3, 2010 | 05:42 AM
JasonZ-YA's Avatar
JasonZ-YA
sure for racing purposes, but i doubt nissan cared for that...
My design engineer bud on the Z program said it was made of hollow ductile steel to be the weak point on purpose......many threads on my350z of people bending them after minor curb checks....
keeps nissan out of major liabilty "if other" parts broke..
Also its ideal in a crash situation for the wheels to tuck under versus any other...
plus the oem camber arm arm diameter is small, doesn't hit end link due to how small in dia it is.....how thick/dia is your "tested" camber arm? your current spl camber arms are large diameter tube arms and of course would need to be kinked to clear...
*EDIT:
https://my350z.com/forum/6115444-post1.html
https://my350z.com/forum/6116366-post28.html
https://my350z.com/forum/6116558-post30.html
-J
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
