Eibach Sportline springs camber?
Old May 2, 2010 | 04:51 PM
CS350Z86's Avatar
CS350Z86
Default Eibach Sportline springs camber?
I just ordered the Eibach sportline springs which lowers the car 1.2" all around. I also ordered the ichiba rear camber kit because i read around that it's a must to do the rears. I talked to wheeldude.com & eibach and said you should be fine to get the alignment into factory spec for the front without the front control arms.
Is there anyone with these springs that are okay without the front camber kit and within factory spec?
They said to wait 2 weeks for the springs to settle before doing an alignment. Can i get the springs installed & rear camber kit wait 2 weeks then do a alignment then put new wheels on. Different wheels don't have no effect on the alignment correct? I just want to get it all done before the new wheels because there on preorder.
Thanks!
Old May 2, 2010 | 05:31 PM
CORNELL's Avatar
CORNELL
you will need to get the alignment after installing the arms, most places offer programs starting from 6 months to lifetime so you can go back and get it redone. 3 year alignments at my shop cost $149. you will need rear toe bolts to get toe in spec, it kills tire life more than camber does. toe out is commonly mistaken for camber wear.
Old May 2, 2010 | 05:37 PM
calin's Avatar
calin
I had my Eibach Sportline springs for about 25-30k miles with only a rear camber kit and never had a problem with camber wear on the front tires. And like you said, your rear tires will have some crazy camber after the spring install so that rear camber kit will really come in handy.
Old May 2, 2010 | 08:03 PM
zerostyle's Avatar
zerostyle
i have eibach pros, 1inch all around...and i got it aligned at firestone...the everything was within oem ______ (cant think of word) except the front camber which was off by like 0.2 or 0.3 or something like that...so if anything you would near camber arms for the front?
Old May 3, 2010 | 04:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Thanks!
1. The Sportline lowers the Z more than 1.2 inches - closer to 1.5
2. there is no adjustment for front camber on a 350Z from the factory. The only way to do it is via aftermarket a arms
3. different wheels can have an affect on the alignment, depends on their exact spec, tire spec/condition, etc
Old May 3, 2010 | 04:37 AM
JasonZ-YA's Avatar
JasonZ-YA
Correct!!!
My best guess would be that your front camber without buying after market front upper control arms, to adjust camber will fall at about -1.7 or -1.8...where that ends up being about .5 out of range - but on a daily driven car really isn't that bad on the "FRONT"..........Front being non driving tires - so many dont spend the cash to buy front upper control arms/A-arms....
The rear you will need what others mentioned the spc toe bolt at a minimum and the rear camber arm and you will get into spec for rear...
Please ask any and other questions here after reading on this thread:
https://my350z.com/forum/brakes-and-...ion-101-a.html
As that thread would have answered all your questions..
/thread.
-J
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
