How much brake fluid needed BBK front & rear?
Old May 9, 2010 | 05:55 AM
sluggoZ's Avatar
sluggoZ
Default How much brake fluid needed BBK front & rear?
How much brake fluid do I need to buy?
Thanks!
Old May 9, 2010 | 06:38 AM
diablox1's Avatar
diablox1
did you increas/reduce your reservoir size? if not, it should be nearly the same. just buy a few bottles, use what you need, take the un-opened bottles back.
Old May 9, 2010 | 07:23 AM
DavesZ#3's Avatar
DavesZ#3
It depends on how much brake bleeding you're going to have to do to get all the air out of the system. It usually takes me about 32oz to flush the system totally, so figure at least that much.
Old May 9, 2010 | 07:30 AM
sluggoZ's Avatar
sluggoZ
Thanks!
Old May 9, 2010 | 10:36 AM
terrasmak's Avatar
If you have the motive bleeder from Z1 its less than 2 pints to bleed your hole car. I love that tool.
Old May 9, 2010 | 11:56 AM
MicroSmurf's Avatar
MicroSmurf
When I did my BBK install I purchased 4x 32oz. bottles. You should only need 3 but I didn't feel like making another trip to the store just in case I messed up. Also, I purchased one of those motive bleeders online and that thing is the biggest POS. Don't believe the hype. I should have listened to everybody that keep saying "do it the 2-person old fashion way". I ended up selling that motive bleeder on craigs and did the 2-person way and it was so much easier.
Old May 9, 2010 | 01:23 PM
sluggoZ's Avatar
sluggoZ
I appreciate all the input!
Old May 9, 2010 | 10:34 PM
Mike@Blackline's Avatar
Mike@Blackline
in for reasons of said shittyness
Old May 10, 2010 | 02:59 AM
mw9's Avatar
mw9
Do explain, never heard any problems with the motive bleeders. I just bought one, so I would like to know. Thanks
Old May 10, 2010 | 07:58 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
We always recommend the 2-person method based on countless numbers of call from people complaining of a mushy pedal after install of a BBK or even just lines when using pressure bleeders. (there are professional grade systems that are fine, but they are many thousands of dollars and are not commonly used in home garages) The problem is that most pressure bleeders cannot create the same kinds of pressures that the pedal/master/booster create. While a pressure bleeder can make it easier to get most of the air out of the system, you should always at least finish up with the traditional method to get the best possible feel.
Old May 10, 2010 | 08:17 AM
z31maniac's Avatar
z31maniac
^Agreed. It's what we had to do on my BMWs that we installed BBKs on.
The pressure bleeder would get it most of the way there, but the traditional method had to be used to finish up.
Old May 10, 2010 | 11:25 AM
sluggoZ's Avatar
sluggoZ
I'm glad I posted this thread!
m_0g
Jun 3, 2021 10:05 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
SonnyWu
Nov 24, 2015 08:19 PM
hardkicks
Sep 20, 2015 12:28 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
