vibrations after new tires/brake pads
May 19, 2010 | 01:44 PM
i just recently bought an 07 enthusiast. the rear tires were nearly bald and needed replacing as did the brake pads..so i went to mavis and got some bridgestone potenza pole positions installed in the rear as well as rear brake pads. since then, i've been experiencing vibrations when braking. i didn't notice these vibrations before and now it's pretty apparent. they told me warped rotors but i find it hard to believe my rotors magically warped the same day mavis was treating my car..any ideas?
May 19, 2010 | 01:55 PM
Although the symptoms match warped rotors, i seriously highly doubt you warped them...
Did they balance the wheels? Do you have new weights in the wheel or are the old weights still on?
May 19, 2010 | 01:57 PM
Did you/they bed in the brakes properly?
May 19, 2010 | 02:00 PM
i assumed they balanced the wheels, and i'm not sure about the weights..is there any way for me to check myself?
May 19, 2010 | 02:01 PM
Quote:
Originally Posted by
DavesZ#3
^ But no bed-in wouldn't cause vibrations, just glazed pads/rotors...right?
May 19, 2010 | 02:02 PM
foshau23
lol Look inside the wheel.
May 19, 2010 | 02:21 PM
GeauxLadyZ
if you don't bed in the pads right the pads won't leave an even residue across the surface of the rotor and will cause the shake under braking due to the different friction co-efficient of the two different materials (rotor/pad residue)
May 19, 2010 | 02:26 PM
dont hate on a noob lol..the weights were definitely replaced though
May 19, 2010 | 03:33 PM
New pads caused the vibration? Interesting.
May 19, 2010 | 04:30 PM
it's actually not that bad of a vibration after i went out and drove it again, but i still don't believe them that i have a warped rotor.
May 19, 2010 | 04:54 PM
Doubt it. You would have had to seriously work your brakes to get them that hot.
May 19, 2010 | 05:24 PM
They may not be warped badly, but a simple resurfacing of the rotors wouldn't hurt to guarantee they are perfectly smooth.
May 19, 2010 | 07:12 PM
should stop if its the brakes they have a break in period so just break longer when you going to stop, like start earlier.
May 20, 2010 | 05:35 AM
notFSTenuff
How? You had it right the first two times, but managed to have your brain take a dump on the third attempt.
May 20, 2010 | 04:42 PM
that could be it because the vibrations seem to be fading a bit
May 26, 2010 | 06:03 PM
vibrations definitely aren't fading..time to get new rotors or have them checked out by someone else and see what they think
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
samansharif
Sep 25, 2015 12:31 PM
brake ,
brakes ,
braking ,
break ,
installing ,
pads ,
r35 ,
rotor ,
rotors ,
stop ,
tiores ,
tires ,
vibrate ,
vibration ,
vibrations
