Noise once I start rolling
Old Jun 4, 2010 | 01:43 PM
bp350z's Avatar
bp350z
Default Noise once I go from start to rolling
Once I start to from a stop then to a roll I hear a noise like a click here and there. What could this be? After the roll I dont hear it again.
Old Jun 4, 2010 | 01:48 PM
phreaktor's Avatar
phreaktor
Design Engineer
It's a bent crankshaft.
Seriously, does the frequency increase with speed? Does it go away after a bit? Have you done any work on it recently.
Old Jun 4, 2010 | 02:18 PM
terrasmak's Avatar
axle click probably , or you have a rock in a tire.
Old Jun 4, 2010 | 02:40 PM
Originally Posted by bp350z
What could this be?
It could be that you are not using search?
Old Jun 4, 2010 | 02:44 PM
Waiz's Avatar
Waiz
Please use the site search for the terms "axle click".
This issue has been covered extensively.
Old Jun 4, 2010 | 03:14 PM
bp350z's Avatar
bp350z
Is this something i should fix asap or can it wait?
Old Jun 4, 2010 | 03:23 PM
glenns280's Avatar
glenns280
wait like till sumin falls off
bp350z's Avatar
bp350z
It is my driveshaft by the way sorry for not searching 1st.
Old Jun 4, 2010 | 03:25 PM
bp350z's Avatar
bp350z
I am new to these cars so any information will help...
Old Jun 4, 2010 | 03:27 PM
Waiz's Avatar
Waiz
https://my350z.com/forum/maintenance...-warranty.html
I typed "axle click" into the search and was given the above.
Old Jun 4, 2010 | 05:11 PM
myfirstzcar's Avatar
myfirstzcar
You have to either replace the outer cv joint(s) and bearing(s) or do what I did. I am the warranty on my Z. Take the wheel off and loosen the axle nut almost all the way. Tap gently with a hammer, the axle will slide in about 1-1+1/2 inches. Get some spray copper anti-seize with a straw and very carefully spray it into the splines from both sides. Get a fair amount of it in there but don't make a mess. Then just torque the nut to about 180ft/lbs and the click is gone. I just did this a week ago so I'm not sure how long it will last, but it worked. I put the anti-seize on my squeaky clutch fork pivot ball over 2000 miles ago and it's still silky smooth, it's good stuff, but I did tell you the right way to do it. The clicking cv and bearing should never be a problem anyway, just annoying.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
