Camber on passenger side (F & R) are off - suspension problem?
Old Jun 9, 2010 | 11:29 AM
choueifati's Avatar
choueifati
Default Camber on passenger side (F & R) are off - suspension problem?
So, I went to get my car aligned today after buying some new front tires. I have a stock 2003 350z Touring model with 88K miles on it. I had some inside wear on the front tires where the inside of the tires were bald compared to the outside of the tires. Here are my current alignment measurements:
Left Front:
Camber = -.8
Caster = 8.8
Toe = .06
Left Rear:
Camber = -1.6
Toe = .08
Right Front:
Camber = -1.4
Caster = 8.4
Toe = .06
Right Rear:
Camber = -2.2
Toe = .11
The mechanic who aligned my car told me that i may need to get an adjustable camber kit to get the car within specs. Is that true? Or, do I need to replace the shocks on the car? The mechanic told me that there was no bleeding or any evidence of overuse of the shocks but I just don't know how long shocks are supposed to last on this car. It's a bit odd that only the camber on the passenger side of the car is off and can't be adjusted while the driver's side is within range.
Any input would be appreciated.
Thanks
Old Jun 9, 2010 | 11:31 AM
Nexx's Avatar
Nexx
rear camber is slightly adjustable unless it was already adjusted all the in already. camber arms arent expensive so get a set if you need them.
Old Jun 9, 2010 | 12:32 PM
terrasmak's Avatar
88k miles you shocks have been bad for a while now. Camber out of whack a bit happens, but -1.4 isn't very bad.
What i would do, new shocks, and swap the springs from side to side when you do the install. Pass side is the side that always sags.
Old Jun 9, 2010 | 12:53 PM
diablox1's Avatar
diablox1
Old Jun 9, 2010 | 12:56 PM
03threefiftyz's Avatar
03threefiftyz
More likely shot bushings than the shocks.......could be both though.
Old Jun 9, 2010 | 01:15 PM
choueifati's Avatar
choueifati
03threefiftyz: which bushings are you talking about?
terrasmak: any suggestions on shocks? i'm not looking to change things too far out of stock but a stiffer suspension might be nice.
Thanks for the input...
Old Jun 9, 2010 | 01:19 PM
03threefiftyz
Over time the factory rubber bushings throughout wear and tear....fairly common.
Old Jun 9, 2010 | 01:25 PM
choueifati's Avatar
choueifati
03threefiftyz: do you happen to know which bushings would cause the camber to be out of whack? I know there are a lot of bushings in the suspension.
Thanks,
Old Jun 9, 2010 | 01:35 PM
terrasmak's Avatar
LCA can, the upper control arm bushings car, and even the strut mount bushing will cause a little bit of camber.
Old Jun 9, 2010 | 01:36 PM
03threefiftyz
Could just be the bushings within the camber arms themselves....it's just speculation. It could be a number of things man.
Old Jun 10, 2010 | 02:29 PM
This number concerns me.
TDPrank
Sep 29, 2015 12:51 PM
Dymsi
Sep 29, 2015 11:32 AM
TDPrank
Sep 28, 2015 06:29 AM
samansharif
Sep 25, 2015 12:31 PM
