bronze ring on rotors - what is it?
Old Jun 14, 2010 | 01:49 PM
ZeroFear's Avatar
ZeroFear
Default bronze ring on rotors - what is it?
I recently got new rotors ( R1 blanks ) and Nismo R-tune pads. I did a bed in procedure for the pads, but now I have bronze/copper colored ring on the inside of my rotor. Is that normal?
Old Jun 14, 2010 | 01:52 PM
godzilla619's Avatar
godzilla619
that is normal, it's the area of the rotor your pads are not touching.
Old Jun 14, 2010 | 02:07 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
rust
Old Jun 14, 2010 | 03:49 PM
Barnabas's Avatar
Barnabas
National Z Club President
like this?? its just rust like everyone else said.
Old Jun 14, 2010 | 03:50 PM
UMW350Z's Avatar
UMW350Z
they didn't treat the hat? that sucks
Old Jun 14, 2010 | 05:38 PM
bimmertech's Avatar
bimmertech
you get what you pay for....
fwiw even the stoptech "coated" rotors(1pc) don't cover the entire unswept area.
however, the oem rotors do.
Old Jun 14, 2010 | 05:56 PM
350ZTheStandard's Avatar
350ZTheStandard
OP, you will okay hito, simply minor rust.
Old Jun 14, 2010 | 06:07 PM
dkmesa350z's Avatar
dkmesa350z
surface rust. I painted the hats on my r1 blanks with black caliper paint.
Old Jun 14, 2010 | 06:19 PM
350ZTheStandard
^ Nice, I will do this when I change out my brake pads later this summer. I actually was too lazy to do this when I chaged out the rotors almost 3 years ago. Why didn't you get the drilled & slotted rotord from r1
Old Jun 15, 2010 | 06:05 AM
drivessidewayz's Avatar
drivessidewayz
I'm assuming we're talking about R1Concepts. If you call and tell them you have that ring, they may send you new ones completely coated in zinc. Then you just have to burn off whatever your pads are touching and you're good.
Old Jun 15, 2010 | 12:47 PM
winchman's Avatar
winchman
What's the purpose of the tool shown in post #8, and how does it work?
Old Jun 15, 2010 | 12:48 PM
Barnabas's Avatar
Barnabas
its a fender rolling tool
Old Jun 17, 2010 | 09:47 AM
ZeroFear's Avatar
ZeroFear
sounds like a good solution. It sucks that I got there "premium" blank, but that area is prone to rust. Should have been painted or something from the getgo.
Old Jun 17, 2010 | 09:55 AM
JasonZ-YA's Avatar
JasonZ-YA
Wire brush then rust converter (sold at autozone, etc)...once dry your good, or you can spray with primer.........cover studs, don't get paint on the threads..
This stuff:
http://www.autobodytoolmart.com/klea...2-p-12824.aspx
Then High temp paint or wheel paint has better additives for lasting on a rotor:
Related thread:
https://my350z.com/forum/wheels-and-...ndle-area.html
UPDATE:
see post 5 here:
https://my350z.com/forum/wheels-and-...ml#post7229635
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
