Odd noise from coilover
Old Jun 22, 2010 | 01:25 AM
jasabeast's Avatar
jasabeast
Default Odd noise from coilover
Last friday i did an oil change and i usually only jack up the passenger side front since im skinny enough to squeeze under. I do try to jack it up pretty high tho. Well ever since then my driverside rear coilover has been making a loud clunk noise over any bump. I havnt jacked the rear up yet to see what exactly is wrong. Has anyone else had this happen before? Im hoping something is loose and its a easy fix but idk. Im almost positive its my coilover cause it feels a little more bumpy when hitting bumps in the road and it kinda feel like the strut is hitting the strut tower really hard. BTW i have Stance GR+ True Coilovers. Any input or help would be greatly appreciated.
Worse comes to worse it has only been like 7 months so i am still under Stances 1 year warranty and ill have to thro my springs back on for a week or 2 till it gets replaced.
Old Jun 22, 2010 | 08:33 AM
tsar's Avatar
tsar
I have the same problem with my AL+. I've tried many of the fixes that I have found on this site to no avail. I have recently e-mailed Stance to see if they have a fix or at least an answer regarding this issue because it seems to be widespread enough (just do a search for Stance knocking on this site). Maybe someone can chime in and let us know if they've had any luck regarding this annoyance. I'll update as well if Stance ever e-mails me back.
Old Jun 22, 2010 | 09:47 AM
jasabeast's Avatar
jasabeast
i emailed them today no respnse yet..
Old Jun 22, 2010 | 10:44 AM
jasabeast's Avatar
jasabeast
Here are pics of what the strut looks like
Old Jun 22, 2010 | 10:47 AM
JasonZ-YA's Avatar
JasonZ-YA
UUUMMMmmmmm blow coilover....
-J
Old Jun 22, 2010 | 10:58 AM
Russ@Z1's Avatar
Russ@Z1
^ what he said
That's blown.
Old Jun 22, 2010 | 11:00 AM
JasonZ-YA's Avatar
JasonZ-YA
so, you drain "some" of your oil with "only" the passenger side raised up???
If i remember right, the drain is on the passenger side????
wow....just wow...
-J
jasabeast's Avatar
jasabeast
yeah sucks.. its only one coil i checked all the others.. weord cause i never hit potholes or anything like that.. they have like no miles on them even tho they are 7months old. hopefully Stance replaces it for free
Old Jun 22, 2010 | 11:02 AM
JasonZ-YA's Avatar
JasonZ-YA
oh...pics saved so i can update "what blown coilovers look like" on my suspension 101 thread..
-J
Old Jun 22, 2010 | 11:03 AM
Russ@Z1's Avatar
Russ@Z1
wow....just wow...
-J
I was wondering if someone would call him out on the oil changing skills.
I figured he already had an issue to deal with on the coilover and wasn't going to blast him on this.
Old Jun 22, 2010 | 11:07 AM
JasonZ-YA's Avatar
JasonZ-YA
Old Jun 22, 2010 | 11:08 AM
Russ@Z1's Avatar
Russ@Z1
hahaha
just sayin
OP, good luck with Stance. I hope they take care of you.
Old Jun 22, 2010 | 11:09 AM
terrasmak's Avatar
Wow, thats blown
Old Jun 22, 2010 | 11:12 AM
Russ@Z1's Avatar
Russ@Z1
The coilover sacrificed itself to lubricate the ball joint and bushings.
Old Jun 22, 2010 | 11:13 AM
jasabeast's Avatar
jasabeast
lol i was just reading that today J... i thought it was just a loose bolt but unfortunatly not.. whats weird tho is when i put it in the garage for the weekend it drove perfectly fine then backed out of the driveway and it started making that clunk noise.. worst bump i have hit is 95 bridge dips or whatever they are called
jasabeast's Avatar
jasabeast
hahaha the coilover was straight
Old Jun 22, 2010 | 11:14 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
ya that thing is gone for sure.. but on good note - you know what the fix is going to be..
Old Jun 22, 2010 | 12:47 PM
Gsedan35's Avatar
Gsedan35
How the heck did oil manage to make it to the fender wall like that. Normally oil just weep's past the piston shaft seal or past the adjustor seal. If I were Stance I'd be very curious to top the damper off with oil and repressurerise and see where it leaks (IIRC they do not service what they sell however).
Old Jun 22, 2010 | 12:55 PM
Russ@Z1's Avatar
Russ@Z1
I've had a blown coilover before and the air blew the oil inside the fender well and lubricated all my ball joints, bushings, and seals just like the OP's
Old Jun 22, 2010 | 04:38 PM
tsar's Avatar
tsar
The strange thing is that I don't have any oil like that in my wheel well but I still have the really bad knocking sound. Is it possible for it to be blown without the oil leaking out? The noise is pretty bad and I don't see any other possible sources of where it could be coming from other than the shock. Would it be best to put on the stock suspension until I can figure out what the hell the sound is? Also does anybody know if Stance sells individual coilovers?
