Finally getting my Toe fixed, need opinions
Old Aug 16, 2010 | 04:37 PM
JOMZSHAKES's Avatar
JOMZSHAKES
Default Finally getting my Toe fixed, need opinions
Finally getting myself started on going from my tein basic setup to something better
Recently remember rubbing grease off my rear strut and telling myself i would deal with the blown strut later
currently have stock spring bucket in back
ive dropped the rear= 1.5" front =.5" to .7" maybe
with the drop and no toe bolts and the Bigger tires my toe is visually off
-by a lot
my suspension feels top heavy in the rear
because of this and a broken swaybar bracket in front right "allready ordered"
do i need to buy those rubber sleeves for the new motordyne sways
or do i need to stretch them of my damaged nismo sways"
Ive got motordyne sways on the way to be set at full stiffness
25mm spacers for the rear
265/40/r18 "stock width rims" for the rear 245/40/r18 front
heres what im considering...
getting kinetix a arms for front and rear with new stock bushings
"to fix camber, allow me to drop a little more in front"
either going for the spl Midlink to fix my toe issue And keep my rear progressive stock style "tein basic" i have and buying 1 new strut and guessing which one had leaked, or..
Going for a true coilover setup , and getting different rear coilovers
and buying a Adjustable toe arm
Do I need to buy rear camber arms for the true coilover set up or
is that for the stock "progressive" set up only, Do i need those or will rear A-arms adjust my camber enough to have a 3.0 degree camber?
With a true rear coilover set up is there anything obvious that im missing with this set up?
Is this worth it or should i get the $490 SPL midlinks and 1 new rear tein
basic strut "big difference with a drop that ill use driving daily yet agressive"
Should i get Tein rear coilovers? any other opinions whats reasonable?
Price match vs keeping rear set up "basic" with good toe
"looking for something track worthy, yet i will be driving on the street 99% of the time"
So far i have spl rear bushings, quaife diff w/ 4.083 gears stillen headers
cats and true dual, m/d spacer, injen short ram with RC2 air filter
cover that?
Old Aug 16, 2010 | 04:40 PM
JOMZSHAKES's Avatar
JOMZSHAKES
And i allready have the spl endlinks that i was gonna need to replace
the ones that cringe/crack/pop when i go down a drive way
a result of my damaged sway bar bracket in the front right
Old Aug 16, 2010 | 04:41 PM
JOMZSHAKES's Avatar
JOMZSHAKES
-and 20mm spacer for front...
Old Aug 16, 2010 | 04:47 PM
JOMZSHAKES's Avatar
JOMZSHAKES
Will this justify keeping the rear progressive set up i have
"my springs are green though tein basic - this may be stock?"
Old Aug 16, 2010 | 05:20 PM
JOMZSHAKES's Avatar
JOMZSHAKES
https://my350z.com/forum/brakes-and-...mount-mod.html
this is what i was talking about in the above post
Old Aug 16, 2010 | 06:36 PM
JOMZSHAKES's Avatar
JOMZSHAKES
anyone? anything?
Old Aug 16, 2010 | 07:46 PM
adamciya350's Avatar
adamciya350
6 posts in a row all OP
c-c-c-combo breaker!!
Old Aug 16, 2010 | 08:04 PM
terrasmak's Avatar
Get good springs with good shocks or a set of quality coilovers. Also why do you want the sways set to full stiff? Do you want the car to handle like ***? Do you really know how sways work , let alone the rest of your suspension.
Old Aug 16, 2010 | 08:28 PM
JOMZSHAKES's Avatar
JOMZSHAKES
http://www.motordyneengineering.com/...php?cPath=1_13
what would you recommend for stiffness, anyone
ive got a a tanabe 4 point underbrace to stiff up the front and protect my cats
stock strut bar, no solid rear subframe bushings and no solid bushings in the front. only new end links for the rear
is there a adjustable arm for the rear sway bar?
Old Aug 17, 2010 | 07:32 AM
doug_z's Avatar
doug_z
first what u need to do is to figure out what u want to know because you just put a lot of information out there yet what is the real question
Old Aug 17, 2010 | 08:34 AM
Gsedan35's Avatar
Gsedan35
Sway's are about fine tuning a setup's handling to get the at the limit behavior your want. If he's set to full stiff and has found what he likes, no one can tell him he's wrong. Given the tiny 25mm diameter of his front bar, it really should not be a mystery that he's went with full stiff. Bigger issue is the wisdom of knowing that the rear bar is are a more nominal diameter and what that means to the big picture. I simply amazes me what parts get bought without finding out actual specs and making a sound buying decision because you played the field being a truely informed buyer.
Old Aug 17, 2010 | 08:53 AM
terrasmak's Avatar
If you read, he has the bars on the way and they are not installed, and i'll bet with his current setup and street tires full stiff front and rear will be wrong . Also i'm sure reading his posts you will notice he doesn't have a clue about anything suspension related.
Old Aug 17, 2010 | 06:02 PM
JOMZSHAKES's Avatar
JOMZSHAKES
Thats why im here-
So, im leaning towards stance gr+ coilovers and waiting to save up cash.
will a full coilover setup give me any more troubles other then having to buy a toe arm and camber rod for the rear,
and something about buying a rear upper knuckle?because they wear?
I have no clue what setting i should be aiming for for stiffness i just want it to be lower then what i have, and balance out the set up
1.5 diff
4.083 gears
and a utec tune with my bolt ons
ride quality can be comprimised, i want a performance stance, not
slammed
any other ideas on a good coilover set up that would be better
i dont need constant height adjustments or anything over $2,000.
just something to balance my mods, and get me on the track
Old Aug 17, 2010 | 09:52 PM
terrasmak's Avatar
Just cruise out to the track then , thats all thats needed. Then buy brakes and tires and mod as needed.
Old Aug 18, 2010 | 03:56 AM
JasonZ-YA's Avatar
JasonZ-YA
holy bat man!!! okay OP thats way too many questions.........if you take your time and read through the Suspension 101 thread you should understand the Z's suspension way more and have the answers your looking for suspension related:
https://my350z.com/forum/brakes-and-...ion-101-a.html
be sure to physically get under your car and ensure you know what your looking at, and what I'm referring to in that thread..........if you still don't get it, have a good mechanic buddy help point everything out to you or a friend just help you read through it all while looking at the car.
ask any remaining questions on that thread please.
-J
Uriyo_
Sep 8, 2021 08:46 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
