Can I put 05-08 oem rotors on my 03? (is there a size difference?)
Old Aug 21, 2010 | 03:32 PM
Lefix's Avatar
Lefix
Default Can I put 05-08 oem rotors on my 03? (is there a size difference?)
Hey guys, I tried searching brake conversion and stuff but can't find anything that answers my question..
My question is: is there a size difference on the rotors between the years 03-08?
I think I read somewhere once that 03-04 is a certain size, then Nissan made the brakes bigger on the 05-06 Z's and then they got Even bigger in 07-08, is that true?
I want to know because I want bigger rotors on my 03 Z but I can't afford BBK's right now
Thanks guys
Old Aug 21, 2010 | 04:10 PM
DavesZ#3's Avatar
DavesZ#3
From the FSM, non-Brembo rotors
year_Front ________Rear
'03 296x24mm & 292x16mm
'04 296x24mm & 292x16mm
'05 296x24mm & 292x16mm
'06 320x28mm & 308x16mm
'07 320x28mm & 308x16mm
Old Aug 21, 2010 | 04:35 PM
Lefix's Avatar
Lefix
Oh thank you very much, so is it possible for me to swap 06-08 rotors into my 03? Like do I need to get 06-08 calipers? I want swap both front and rear, what else would I need?
Old Aug 21, 2010 | 05:08 PM
raycs7's Avatar
raycs7
yes
calipers and rotors and pads
Old Aug 21, 2010 | 06:15 PM
DavesZ#3's Avatar
DavesZ#3
Thanks guys
Let's start this over from the beginning. The big question is "why do you want a BBK"? Unless you are tracking your car, you certainly don't need them other than for "looks".
If you can't afford a BBK, and decide to purchase the calipers, rotors and pads from an 06-08 350Z, you could probably spend the same money and get the 370Z setup.
Check this out... https://my350z.com/forum/brakes/4142...at-1200-a.html
Old Aug 22, 2010 | 01:30 PM
Lefix's Avatar
Lefix
Well I was hoping to spend less like maybe $500 on some used 06-08 calipers and get after market slotted and drilled rotors.. :/
I know that I'll get what I paid for, but those 370z brake kit looks like everything is new.. :/ like new calipers when I could possibly save on used calipers lol
Old Aug 22, 2010 | 03:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
then your best bet is a good set of pads, stainless lines, and good fluid
Old Aug 22, 2010 | 05:34 PM
DavesZ#3's Avatar
DavesZ#3
Since you didn't mention budget in your original post, most of us assumed your desire for a BBK meant you knew that BBKs run $2000 - $6000 and more.
As Adam pointed out SS lines = $150; pads = $300; fluid = $20 -- there goes your $500 budget already.
Old Aug 22, 2010 | 07:31 PM
I found the brakes you are looking for in the marketplace. All you have to do is look.
Old Sep 29, 2010 | 10:30 AM
bkaa's Avatar
bkaa
when swapping 06+ brakes onto a 03-05 do I have to change any other parts besides, calipers, rotors, pads and lines?
Old Sep 29, 2010 | 11:22 AM
shingr's Avatar
shingr
for regular brakes. lines are an option
Old Sep 29, 2010 | 01:19 PM
Z1 Performance
Former Sponsor
caliper brackets are different, bolts may also be different
unless someone is giving you the setup for free, it's not worth the time, effort or money
Old Sep 30, 2010 | 06:09 AM
GT-Rob's Avatar
GT-Rob
Agreed. Yes an 06+ setup is cheaper then a brembo/aftermarket, but isn't near the performance difference to your current setup.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
