Ok to use OEM Toe Nut on SPC Toe Bolt?
Old Sep 4, 2010 | 06:48 PM
abo's Avatar
abo
Default Ok to use OEM Toe Nut on SPC Toe Bolt?
Just came back from the alignment shop. Car has way too much toe in. I have the SPC rear toe bolts but I'm missing one nut. Does anyone know if I can use the OEM toe nut on the SPC toe bolt before I get started?
Sorry its really hard to search on the blackberry. Thank you in advance!
-Abo
Old Sep 4, 2010 | 09:28 PM
JasonZ-YA's Avatar
JasonZ-YA
yes..........its fine to use..
-J
Old Sep 5, 2010 | 03:58 PM
abo's Avatar
abo
I tried using the oem toe nut. Doesn't seem to thread on correctly. The thread seems closer together on the oem bolt.
Old Sep 5, 2010 | 10:03 PM
winchman's Avatar
winchman
Why not take it back to the alignment shop, and have them do their job correctly?
Old Sep 5, 2010 | 10:08 PM
abo's Avatar
abo
i just finished lowering my car on stance gr+. im guessing that the car was too low for the stock toe bolts to get into spec.
just an fyi for anyone that is missing a nut for their SPC toe bolt. You can pick one up at a Home Depot. I bought the lock nut M12x1.75
350z82
Oct 1, 2015 06:25 PM
