Front Coilover Camber
Old Oct 3, 2010 | 10:58 AM
tpain's Avatar
tpain
Default Front Coilover Camber
So... If I install coilovers with adjustable camber, do I eliminate the need for aftermarket upper control arms? How specifically is camber adjusted through the coilover itself? Overall length of the shock? Thanx y'all!
Old Oct 3, 2010 | 11:05 AM
terrasmak's Avatar
Camber is not adjustable thru the coilover, we have a modified double A arm front end. Upper adjustable arms are required for camber adjustment.
Old Oct 3, 2010 | 11:43 AM
tpain's Avatar
tpain
i see. so when they say the stance GR+ has adjustable camber upper mounts, what exactly do they mean?
Old Oct 3, 2010 | 11:53 AM
tpain's Avatar
tpain
Ooohhhh... That must be a general feature. Cause the lower end of the strut cannot be "fixed" to the knuckle with two sets of bolts allowing use of like a camber plate 'er something at the top of the strut. Something like that right?
Old Oct 3, 2010 | 01:45 PM
terrasmak's Avatar
Its a general statement, and civics, 240's etc etc will be camber adjustable from the top mount.
Old Oct 3, 2010 | 02:06 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
If they specifically refer to the z and g applications with that language it translates to "we don't know the products we are selling and/or we don't describe them accurately"
Old Oct 3, 2010 | 03:35 PM
tpain's Avatar
tpain
Gotcha. Now most dudes doing a standard drop should be fine without adjustable uppers for a while right? Looking at -1.5 to -2.0 on the front camber. I'm thinkin' I wanna be in that range on the fronts anyway, I know it's outta spec n all, but sounds like a lot people get some nice handling with those numbers. Would I run into a problem with asymmetry, like the front left being -1.5 and the right ends up at like -1.7?
Old Oct 3, 2010 | 03:40 PM
terrasmak's Avatar
Probably, but there is only one way to find out.
Old Oct 3, 2010 | 03:48 PM
tpain's Avatar
tpain
Yep, true. Thanx for the input y'all
Old Oct 3, 2010 | 06:24 PM
JasonZ-YA's Avatar
JasonZ-YA
EXACTLY!!! the descriptions on literally every dammn website out there is just copy pasted general text...........its ridiculous........
I made this thread to show actual coilovers - as you can see, no camber plates...
ACTUAL COILOVER THREAD:
https://my350z.com/forum/brakes-and-...ic-thread.html
those blanket statements are common to those older cars with crappy mcpherson strut suspension designs......the Z is a long arm SLA suspension design.
https://my350z.com/forum/brakes-and-...ion-101-a.html
-J
Obadabot
Jun 18, 2023 11:31 PM
