Suspension making popping sounds after lowering
Old Oct 15, 2010 | 10:13 AM
Low_MPG_Z's Avatar
Low_MPG_Z
Default Suspension making popping sounds after lowering
Hey guys, I just lowered my car 1.2" and now the front right is making popping noises. I looked and everything looks fine, even tried compressing the suspension with a jack to see if I could find were the noise is coming from.
I only does it when I go over a bump (speed bump, uneven road, pot hole) at lower speeds. It will do it at higher speeds but not like it does at lower speeds.
I'm suspecting it might be the actual strut, I do not want to tear everything down if I do not have to.
If anybody knows what is wrong or how to fix it I would greatly appreciate any info.
Thanks
Old Oct 15, 2010 | 10:16 AM
terrasmak's Avatar
`Could be your sway bar end link binding.
Old Oct 15, 2010 | 10:22 AM
Low_MPG_Z's Avatar
Low_MPG_Z
would it be visible by just looking at it?
Old Oct 15, 2010 | 02:21 PM
thinking's Avatar
thinking
If you temporarily disconnect one end of the sway bar / end link (and zip tie it, so it does not go all over the place) and go for a quick test drive, you can determine if it was binding or not
Old Oct 16, 2010 | 07:00 AM
black_03's Avatar
black_03
Thanks
Same here, what are you lowered on?
Old Oct 16, 2010 | 08:01 AM
Low_MPG_Z's Avatar
Low_MPG_Z
Tanabe Nf210
Old Oct 16, 2010 | 08:41 AM
03threefiftyz's Avatar
03threefiftyz
Sounds like end links to me....
Old Oct 16, 2010 | 09:20 AM
Low_MPG_Z's Avatar
Low_MPG_Z
I did that and the popping still continued.
Could the bushings been damaged in the process of lowering the car? I say that because in order to remove the strut the control arm had to be pushed down to a good bit.
Old Oct 16, 2010 | 09:47 AM
Low_MPG_Z's Avatar
Low_MPG_Z
Theory #2: Could the actual spring be making the noise (ie: its not sitting properly on the upper rubber mount and is moving around) trying to settle out.
Just throwing that out
Old Oct 16, 2010 | 12:55 PM
tumzilla's Avatar
tumzilla
is it a knocking or loud popping sound?
Old Oct 16, 2010 | 03:51 PM
Low_MPG_Z's Avatar
Low_MPG_Z
popping sound
Old Feb 7, 2011 | 03:59 PM
SuperGood's Avatar
SuperGood
OP, any updates?
I lowered mine on Eibach Pro Kit and it's making the same popping noises. It's gotten worse after a few weeks and now if I just turn my steering wheel it'll pop.
Old Feb 7, 2011 | 04:51 PM
tyau's Avatar
tyau
Sounds like endlinks to me too.
Old Feb 7, 2011 | 05:28 PM
Sn8keEyez's Avatar
Sn8keEyez
Did you replace A Arms with SPC or are you still on stock A Arms. If replaced check this: https://my350z.com/forum/brakes-and-...-vs-spl-2.html. And do some searches will lead you to more if this is the case.
Old Feb 8, 2011 | 10:36 AM
scrantonz33's Avatar
scrantonz33
i had the same issue when i swapped springs same springs as yours, when i jacked up the car grabed the bottom of the wheel and lifted up i saw that the nut on the top plate that holds the spring on wasnt tightened all the way. try giving it a try when ever i hit a bumb it would pop like your saying. but again it may not be whats wrong.
Old Feb 8, 2011 | 11:10 AM
SuperGood's Avatar
SuperGood
I only replaced the springs, no A-Arms. I did a quick inspection last weekend and did not notice any loose bolts/nuts. I'll look again when I have more time, thanks for the input.
Old Feb 8, 2011 | 11:43 AM
beezee's Avatar
beezee
Exactly what I was going to say. You can't always tell the nut is not tight just by looking at it. If you dont have a hollow thread tube like the D-Specs you can give it a "little" zip with an impact wrench. I mean "little"
OOPs, I just noticed you posted this back in october. I guess you got it fixed already
07ZEKE
Aug 23, 2021 09:15 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
