Calipers
Old Dec 12, 2010 | 05:06 PM
P&K350Z's Avatar
P&K350Z
Default Calipers
So I would like to upgrade my calipers (front and back) without having to buy an entire BBK. I already have EBC rotors, EBC Yellowstuff pads, SS lines and high temp fluid. In short, just the calipers are missing. I am running the stock ones and the car is a 2006 base model.
My question is, which calipers would be simple drop-ins without having to change everything? I would prefer Wilwood 6 pistons, but any six piston would do so long as it is a direct replacement.
Thanks in advance for your help.
Old Dec 12, 2010 | 05:28 PM
terrasmak's Avatar
Need a facepalm pic
Pads are caliper specific, calipers are rotor specific. In short you are actually missing Calipers, the proper pads for the upgraded calipers, and the proper size rotor for your upgraded calipers. When you order a BBK with the 3 parts listed above they come with the proper brake lines to run.
Old Dec 12, 2010 | 05:32 PM
I think the reason big brakes are called big brakes is because the rotor is bigger than OEM. Good luck on this idea.
Old Dec 12, 2010 | 05:54 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no such animal exists
Old Dec 12, 2010 | 05:57 PM
P&K350Z's Avatar
P&K350Z
Thank you, plan b then...
Old Dec 12, 2010 | 07:12 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
brembos from a junk yard...you have to get new pads and rotors though unless you find those in the mix as well.. oh and new lines..
I paid 700 for new rotors, new lines, and Brembos (and I got them powdercoated)..you wont find anything plug and play except for Brembos bud.. At least not for the price you want them for..
Old Dec 13, 2010 | 12:56 PM
Todd TCE's Avatar
Todd TCE
TCE Performance Products
Not that your plan is not 'doable' but the value is really not there for you. Aside from appearances (granted for some this is the priority) the real net gains come from a larger and heavier rotor. For the more spirited driver rotor mass is your friend. In addition to providing more torque or leverage from having a larger diameter, the rotor is less prone to fade and runs cooler.
For those who want a caliper only kit (speaking each end of the car) I'm certain that I and others could provide you with one however the money spent (let's call it $900 ish for the Wilwoods your reference considering you'd need calipers, brackets, pads, hoses and hardware) that for only 5-600 ish more you'd get the entire 'kit' which would then offer you the improvements in rotor function- mass, cooling, appearance, total weight loss...making the caliper kit on this car not really a great investment.
Old Dec 14, 2010 | 08:00 AM
Chris_B's Avatar
Chris_B
Can't argue with that!
Old Dec 14, 2010 | 08:15 AM
thekinn's Avatar
thekinn
paint. They will look different.. and you wont have to change the rotors or pads.
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
seagrasser
Oct 11, 2015 03:27 PM
350Shadow
Sep 22, 2015 08:30 AM
hardkicks
Sep 20, 2015 12:28 PM
