Brake issue
Old Jan 23, 2011 | 06:56 PM
Dblock55's Avatar
Dblock55
Default Brake issue
Hey all, gonna get straight to point.. my rear drivers side brake pad is wearing like crazy!!!! its gone by the time any of the others have had time to eat away 10%.... the pad thats being worn away is the one on the opposite side of the caliper... so ive always been told that if its that side then the sliding pins are seized... so i took them out sanded them and polished them then greased em up and made sure the pads can slide nicely on them and they do... put new pads on and am getting the same wear.... the caliper seems to come in and out pretty easily.... should i rebuild the caliper for the heck of it or could something else be causing this wear?? im stumped any help is appreciated.
Old Jan 23, 2011 | 07:45 PM
Arvin89's Avatar
Arvin89
hows the rotor?
Old Jan 24, 2011 | 08:49 AM
Dblock55's Avatar
Dblock55
the rotor is not in the best of shape considering that pad got down to the bare metal last track day... but before that it was good and it was still happening...
Old Jan 25, 2011 | 11:29 AM
Chris_B's Avatar
Chris_B
Most likely, it is either caused by a piston sticking in the caliper or by a collapsed rubber brake line. If you live where it snows and they salt the roads, the piston is the first place I'd look.
Old Jan 25, 2011 | 02:45 PM
Dblock55's Avatar
Dblock55
thx a bunch... didnt want to take it apart until i knew that there is a possibility it could be the piston... i live in new york and they do dump a bunch of salt around here in the winter.... the seals are like 40 bux... dunno y they are so expensive... will let you knwo how that goes...
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
