OEM-type vs True Coilovers
Old Jan 26, 2011 | 11:12 AM
angelo_balto's Avatar
angelo_balto
Default OEM-type vs True Coilovers
Hi guys, does anyone know what is the difference in handling / performance of "OEM-type" vs "True" Coilovers??? I see that there are both types produced for the Z...
Of course supposing that they are using the same spring-rates... (and same build quality)
Old Jan 26, 2011 | 12:00 PM
terrasmak's Avatar
Some say the car handles better with OEM style, other say that no matter what config the wheel just see the wheel rate of the spring.
With that said , i went true only because the SPL spring bucket is on backorder for a few months.
Old Jan 26, 2011 | 09:05 PM
tyau's Avatar
tyau
In the geometric standpoint, true coilover style is more linear because the spring is not compressed by leverage.
With the spring bucket, where springs are often placed more towards the center of the vehicle, the rate of spring compression is affected by cornering load and transient speed, and the rate of compression occurs more progressively as a result of leverage.
It's hard to say which one performs better.
Old Jan 27, 2011 | 07:57 AM
betamotorsports's Avatar
betamotorsports
99.9% of the people on this board won't be able to tell the difference. If you're asking the question, you're part of that 99.9%.
Old Jan 27, 2011 | 08:27 AM
RedBullRR's Avatar
RedBullRR
Here's why I would go with OEM Type Coilover...
1 - I'm sure they're was a **** load of research done by the Japanese when making it that way stock.
2 - I feel the mount for the rear will weaken with a true coil over. Meaning the added pressure on the sheet metal is sure to eventually cause a problem down the line.
3 - Price is a difference when the feel isn't.
Old Jan 27, 2011 | 08:31 AM
halfrice's Avatar
halfrice
+1 what he said
Old Jan 27, 2011 | 10:02 AM
JasonZ-YA's Avatar
JasonZ-YA
READ:
https://my350z.com/forum/brakes-and-...er-or-not.html
-J
Old Jan 27, 2011 | 10:35 AM
Zazz93's Avatar
Zazz93
IMO, unless you want to run a toe arm instead of the spring bucket there's no reason to change it.
Old Jan 27, 2011 | 11:50 AM
beezee's Avatar
beezee
Especially with the same build quality in mind as OP stated, there most likely won't be any noticeable difference
Old Jan 27, 2011 | 12:04 PM
350z-Jason's Avatar
350z-Jason
How about the fact it's much easier to install/remove if you want to work on your car... (true style). The OEM-type is a RETARDED design.
Old Jan 27, 2011 | 01:11 PM
Zazz93's Avatar
Zazz93
I disagree. The OEM style is easy to install, provided you're using a floor jack to hold up the spring bucket. The true coilover can't be compressed by hand to fit in the mounting locations like the OEM style can. The only exception that comes to mind is if you run a short setup (with little droop) that slips in.
Old Jan 27, 2011 | 09:00 PM
350z-Jason's Avatar
350z-Jason
My stance's go straight in...
May 30, 2017 03:28 PM
Dymsi
Sep 29, 2015 11:32 AM
